Disables the identity management feature, which tracks users and devices that connect to the switch.
Disabled.
Only admin-level users can execute this command.
If the identity management feature is running and then disabled, all identity management database entries are removed and cannot be retrieved. If identity management is enabled later, the identity management feature starts collecting information about currently connected users and devices.
The following command disables the identity management feature:
disable identity-management
This command was first available in ExtremeXOS 12.4.
