Disable MVRP on a given set of ports.
| mvrp | Multiple VLAN Registration Protocol. |
| port_list | Port(s) on which MVRP is to be enabled. |
| all | All ports. |
Disabled.
Use this command to disable MVRP on given set of ports. MVRP is run on the MVRP enabled ports only if the global setting is enabled. By default MVRP is disabled globally and on individual ports. When MVRP is disabled globally, all MVRP packets will be forwarded transparently.
The following command disables MVRP on ports 4 and 5:
disable mvrp ports 4-5
This command was first available in ExtremeXOS 15.3.
