Configures the loop-detection parameters used by LDP.
| hop-count | Configures the number of LSRs that the label message can traverse. |
| hop_count_limit | Specifies the hop count limit. The valid configuration range is from 1 to 255. |
| path-vector | Configures the maximum number of LSR IDs that can be propagated in the label message. |
| path_vector_limit | Specifies the path vector limit. The valid configuration range is from 1 to 255. |
The default for the hop-count and path-vector limits is 255.
Configuration changes are only applicable to newly created LDP sessions. Disabling and enabling LDP forces all the LDP sessions to be recreated. LDP loop detection must first be enabled for these configuration values to be used.
This command sets the LDP hop count loop detection value to 10. The configured path vector value remains at 255.
configure mpls ldp loop-detection hop-count 10
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
