enable diffserv examination ports
enable diffserv examination ports [port_list | all]
Description
Enables the DiffServ field of an IP packet to be examined in order to select a QoS profile.
Syntax Description
port_list Specifies a list of ports or slots and ports to which the parameters apply.
all Specifies that DiffServ examination is enabled for all ports.
Default
Disabled.
Usage Guidelines
The Diffserv examination feature is disabled by default.
The following command enables DiffServ examination on selected ports:
enable diffserv examination ports 1:1,5:5,6:2
Platform Availability
