Shows the port specific applicant and registrar states and the configured control values for all MVRP enabled ports.
| mvrp | Multiple VLAN Registration Protocol. |
| tag | The 802.1Q VLAN ID. |
| vlan_tag | VLAN ID ranging from 1 to 4094 (default is 2). |
| port_list | Port list separated by comma or "-". |
N/A.
# show mvrp tag 2
Port Applicant Applicant Registrar Registrar
State Control State Control
9 VN On MT Normal
11 QA On IN Normal
13 QA On IN Normal
Applicant States:
AA : Anxious active, AN : Anxious new,
AO : Anxious observer, AP : Anxious passive,
LA : Leaving active, LO : Leaving observer,
QA : Quiet active, QO : Quiet observer,
QP : Quiet passive, VN : Very anxious new,
VO : Very anxious observer, VP : Very anxious passive
Registrar States:
IN : In – Registered, LV : Leaving - Timing out,
MT : Empty - Not Registered
Applicant Control:
On : Transmit On, Off : Transmit Off
Registrant Control:
Fixed : Statically added, Forbidden : Forbidden VLAN,
Normal : Dynamically added
This command was first available in ExtremeXOS 15.3.
