Disables a Web server target.
| xml_target_name | Specifies the name of the xml-notification target. |
N/A.
Use this command to disable a web server EMS target.
The following command disables the Web server target target2:
disable log target xml-notification target2
This command was first available in ExtremeXOS 12.4.
