Configure or clear force-switch or manual-switch for the ERPS ring/sub-ring.
| dynamic-state | Configure force/manual/clear switch on the active ERPS ring. |
| force-switch | Force-switch operation. |
| manual-switch | Manual-switch operation. |
| clear | Clears force-switch/manual-switch. |
N/A.
Use this command to configure or clear force-switch or manual-switch for the ERPS ring/sub-ring.
In non-revertive mode, in the "Pending" state, you can use the clear option of this command to return to the "Idle" state where the blocked link is manually reverted to the Ring Protection Link (RPL).The following command clears force-switch and manual-switch on an ERPS ring named "ring1":
configure erps ring1 dynamic-state clear
This command was first available in ExtremeXOS 15.1.
