Configures a global inter-area filter policy.
| area-identifier | Specifies the OSPF target area. |
| policy-map | Specifies a policy. |
| none | Specifies not to apply an interarea filter. |
N/A.
For switches configured to support multiple OSPF areas (an ABR function), a policy can be applied to an OSPF area that filters a set of OSPF inter-area routes from being sourced from any other areas.
The following command configures an inter-area filter policy, nosales:
configure ospf area 0.0.0.6 interarea-filter nosales
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
