Shows Network Address Translation (NAT) VLAN information.
| ip | Shows Internet Protocol (IP) information. |
| nat | Shows NAT information. |
| vlan | Specifies VLAN NAT information. |
| vlan_name | Specifies which VLAN to show NAT information for. |
N/A.
To view information for a specific VLAN, specify the VLAN name when running this command.
The following example shows VLAN NAT information:
# show ip nat vlan VLAN Name Direction ================================ ========= engineering Both in Ingress out Egress =========================================== Total Number of NAT VLANs : 3 Maximum number of NAT VLANs : 4
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
