Shows forwarding hardware table utilization statistics.
| hardware-utilization | Specifies showing hardware table utilization statistics. |
| slot | Specifies selecting slots. |
| slot_num | Specifies which slots to show statistics for. |
| all | Specifies showing statistics for all slots. |
Shows forwarding hardware table utilization statistics with L2, L3 and ACLs configured.
The following example shows table utilization statistics:
# show forwarding hardware-utilization
Hardware Table Utilization Statistics
Slot: 1
Type: X870-32c
Resource Type Current Maximum % Util.
MAC Entries 0 73727 0
Host Entries 0 73728 0
IPv4 Entries 0 73728 0
IPv6 Entries 0 36864 0
Long IPv6 Entries 0 2048 0
Total Routes 0 16384 0
IPv4 Neighbors 0 N/A N/A
IPv6 Neighbors 0 N/A N/A
IPv4 Routes 0 N/A N/A
IPv6 Routes 0 N/A N/A
ECMP Next Hops 0 1023 0
ACL Ingress Entries 40 6144 0
ACL Ingress Counters 0 38912 0
ACL Ingress Meters 0 2048 0
ACL Ingress Slices 0 12 0
ACL Egress Entries 0 1024 0
ACL Egress Counters 0 1024 0
ACL Egress Meters 0 1024 0
ACL Egress Slices 0 4 0
ACL VLAN Entries * 1 2048 0
ACL VLAN Slices * 1 4 25
Legend: N/A - Maximum not defined in published sFlow structure.
* - Resource type not defined in published sFlow structure.
Also see IP usage in 'show iproute reserved-entries statistics'.
This command was first available in ExtremeXOS 22.6.
Legend explaining N/A entries was added in ExtremeXOS 30.1.
ACL VLAN entries and slices was added in ExtremeXOS 30.7.
