Configures the destination address of the router advertisement messages.
| multicast | Specifies multicast setting. |
| broadcast | Specifies broadcast setting. |
| mininterval | Specifies the minimum time between advertisements. |
| maxinterval | Specifies the maximum time between advertisements. Default is 600. |
| lifetime | Specifies the lifetime of the advertisement. Default is 1800. |
| preference | Specifies the router preference level. Default is 0. |
Broadcast (255.255.255.255). The default mininterval is 450.
ICMP Router Discovery Protocol (IRDP) allows client machines to determine what default gateway address to use. The switch sends out IP packets at the specified intervals identifying itself as a default router. IRDP enabled client machines use this information to determine which gateway address to use for routing data packets to other networks.
The following example sets the address of the router advertiser messages to multicast:
configure irdp multicast
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.1.1 Licensing Guide document.
