This stops the transmission for both continuous and on-demand mode.
disable cfm segment frame-loss measurement segment_name mep mep_idThis command stops the transmission of the LMM frames for a particular cfm segment.
segment_name |
An alpha numeric string identifying the segment name. |
N/A.
This below command stops the transmission of the LMM frames for a particular cfm segment. This stops the transmission for both continuous and on-demand mode.
disable cfm segment cs2 frame-loss measurement mep 3
This command was first available in ExtremeXOS 15.1.
