Shows the pre-defined action set for use in RADIUS Change of Authentication (CoA).
| access-list | Specifies access-list features. |
| action-set | Defines viewing the set of actions applied to multiple sets of match conditions. |
| set_id | Specifies viewing a particular action set identified with the global action-set ID (range 1–63). |
N/A.
If you do not specify a set_id, all actions sets appear.
You can made configuration changes using the create policy access-list action-set set-id [{drop | forward} {cos cos} {mirror-destination control_index} {syslog}] command.
The following example shows information for action set "1":
# show policy access-list action-set 1
PID |ACL/Rule/Match |Match Data |Msk|PortStr |ST|S|VLAN|CoS |Mir|
| action set 1 | | | |NV|S| | 3| |
This command was first available in ExtremeXOS 30.5.
