configure access-list delete
configure access-list delete ruleName [ any | vlan vlan_name | ports port_list | all] {ingress | egress}
Description
Removes a dynamic ACL rule from the specified interface.
Syntax Description
ruleName Specifies a dynamic ACL rule name.
any Deletes this ACL as the wildcard ACL.
vlan_name Specifies the VLAN on which this ACL is deleted.
port_list Specifies the ports on which this ACL is deleted.
all Deletes this ACL from all interfaces.
ingress Deletes the ACL for packets entering the switch on this interface.
egress Deletes the ACL for packets leaving the switch from this interface.
Default
The default direction is ingress.
Usage Guidelines
Specifying the keyword all removes the ACL from all interfaces it is used on.
The following command removes the dynamic ACL icmp-echo from the port 1:2:
configure access-list delete icmp-echo ports 1:2
This command was first available in ExtremeXOS 11.3.
Platform Availability
