Exports a disk image of an existing virtual machine (VM).
| vm | Virtual machine. |
| vm_name | Specifies the VM to export a disk from. |
| image | Saves (exports) the disk image of a VM in current format (QCOW2 or VMDK). |
| image_file | Specifies the file name for the exported VM disk image. File extension are appended if not specified. |
N/A.
N/A.
The following example exports the disk image from VM "testvm" to a file named "testvmimage":
# save vm testvm image testvmimage
This command was first available in ExtremeXOS 30.4.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Core or Premier license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.1.1 Licensing Guide .
