Enables IP multicast tunnel forwarding on an IP interface.
| tunnel_name | Specifies a tunnel name. |
Disabled.
If no options are specified, all configured IP interfaces are affected. When new IP interfaces are added, IPMC forwarding is disabled by default.
IP forwarding must be enabled before enabling IPMC forwarding.
The following example enables IPMC forwarding on the tunnel accounting:
enable ipmcforwarding tunnel accounting
This command was first available in ExtremeXOS 32.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
