Removes an MSDP mesh-group.
| mesh-group-name | Specifies the name of the MSDP mesh-group. The character string can be a maximum of 31 characters. |
| vrname | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
N/A.
SA messages received from a peer in a mesh-group are not forwarded to other peers in the same mesh-group.
Use the delete msdp mesh-group command only if you created a mesh-group that you want to remove. By default, there is no MSDP mesh-group.
The following example removes a mesh-group called "verizon":
delete msdp mesh-group verizon
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
