Displays LDP information about MPLS interfaces. Summary information is displayed in tabular format for all VLANs that are configured for MPLS.
| vlan | Displays LDP interface information for one VLAN. |
| vlan_name | Specifies the name of the VLAN. |
| detail | Displays LDP interface information including LDP control packet counts. |
| counters | Displays only the LDP control protocol packet counts. |
N/A.
If the optional detail keyword is specified, the information is shown in verbose form and LDP control packet counts are displayed. If the optional counters keyword is specified, only the LDP control protocol packet counts are shown. The counters are described in RFC 3036, LDP Specification.
The following command displays detailed LDP information for the interface associated with VLAN 1:
# show mpls ldp interface vlan1 detail VLAN Name : vlan1 Local IP Address : 11.121.96.20 MPLS Admin Status : Enabled MPLS Oper Status : Enabled LDP Admin Status : Enabled LDP Oper Status : Enabled LDP UpTime : 0d:1h:59m:56s Current Adjacencies : 1 Negotiated Hello Hold Time : 15000 ms Time to Send Next Hello : 4060 ms Link Targeted Counter Adjacencies Adjacencies ------------------------------ ----------- ----------- Shutdown Notifications (Rcvd) 0 0 Shutdown Notifications (Sent) 0 0 Failed Session Attempts (NAKs) 0 0 Hello Errors 0 0 Parameters Advertised Errors 0 0 Max PDU Length Errors 0 0 Label Range Errors 0 0 Bad LDP ID Errors 0 0 Bad PDU Length Errors 0 0 Bad Msg Length Errors 0 0 Bad TLV Length Errors 0 0 Bad TLV Value Errors 0 0 Keep-Alive Timeout Errors 0 0
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
