Displays information about one or all VMANs.
The information displayed for this command depends on the platform and configuration you are using.| vman_name | Specifies that information is displayed for the specified VMAN. |
| vman_list | Specifies the vman list. |
| tag | Specifies a VMAN using the 802.1Q tag. |
| detail | Specifies that all information is displayed for each VMAN. |
| ipv4 | Specifies IPv4. |
| ipv6 | Specifies IPv6. |
Summary information for all VMANs on the switch.
None.
The following example displays a list of all the VMANs on the switch:
# show vman -------------------------------------------------------------------------------------- Name VID Protocol Addr Flags Proto Ports Virtual Active router /Total -------------------------------------------------------------------------------------- le1 4091 ------------------ ----------------a ANY 2 /2 VR-Default le2 4090 ------------------ ----------------a ANY 0 /0 VR-Default vm1 4089 ------------------ ----------------- ANY 0 /0 VR-Default -------------------------------------------------------------------------------------- Flags : (a) Learning Domain (C) EAPS Control vlan, (E) ESRP Enabled, (f) IP Forwarding Enabled, (i) ISIS Enabled, (I) IP Forwarding lpm-routing Enabled, (L) Loopback Enabled, (m) IPmc Forwarding Enabled, (n) IP Multinetting Enabled, (N) Network LogIn vlan, (o) OSPF Enabled, (p) PIM Enabled, (P) EAPS protected vlan, (r) RIP Enabled, (T) Member of STP Domain, (v) VRRP Enabled, (B) 802.1ah Backbone VMAN, (S) 802.1ah Service VMAN Total number of vman(s) : 3
The following example displays information on a single VMAN named vman1:
# show vman vman1
VMAN Interface with name vman1 created by user
Admin State: Enabled Tagging: 802.1Q Tag 100
Virtual router: VR-Default
IPv4 Forwarding: Disabled
IPv6 Forwarding: Disabled
IPv6: None
STPD: None
Protocol: Match all unfiltered protocols
Loopback: Disabled
NetLogin: Disabled
QosProfile: None configured
Egress Rate Limit Designated Port: None configured
Flood Rate Limit QosProfile: None configured
Ports: 2. (Number of active ports=0)
Tag: *1, *2
CEP: *3: CVID 20-29
*4: CVID 10-19 translate 20-29
*5: CVID 10-19 translate 20-29,CVID 30
Flags: (*) Active, (!) Disabled, (g) Load Sharing port
(b) Port blocked on the vlan, (m) Mac-Based port
(a) Egress traffic allowed for NetLogin
(u) Egress traffic unallowed for NetLogin
(t) Translate VLAN tag for Private-VLAN
(s) Private-VLAN System Port, (L) Loopback port
(x) VMAN Tag Translated port
(G) Multi-switch LAG Group port
The Port CVID output was added in the display of show vman vlan_name | detail in ExtremeXOS 15.3.2:
VMAN Interface with name vm1 created by user
Admin State: Enabled Tagging: 802.1Q Tag 1000
Description: None
IPv6: None
STPD: None
Loopback: Disabled
NetLogin: Disabled
Ports: 3. (Number of active ports=3)
Untag: *21: Port CVID 5,
*24: Port CVID 7,
Tag: *22
The show vman detail command shows all the information shown in the show vman vlan_name command, but displays information for all configured VMANs.
This command was first available in ExtremeXOS 11.0.
Information on IEE 802.1ah was added in ExtremeXOS 11.4.
The tag option was added in ExtremeXOS 12.4.4.
Port CVID output was added in ExtremeXOS 15.3.2.
The vman_list variable was added in ExtremeXOS 16.1.
