The Switch Engine software features are listed in the following table are managed as feature licenses. Feature licenses are distributed in one of the following forms:
For feature license and installation instructions, see Installing a Modular Software Package in the Switch Engine v33.1.1 User Guide .
Secure Shell 2 (SSH2) is not provided as a feature license. It is incorporated into the main Switch Engine software image and is not provided as an XMOD. However, SSH2 contains strong encryption algorithms that heighten the export controls required in the US and other countries. When downloading the Switch Engine software image, you are required to verify that you meet the export clearance requirements. For more information, see Software Upgrade and Boot Options in the Switch Engine v33.1.1 User Guide .
For more information on SSH2, see Using Secure Shell 2 in the Switch Engine v33.1.1 User Guide .
| Feature License | Feature | Platform support | XMOD Required |
MPLS Feature The MPLS Feature is available as part of the Premier license under the Platform Support column. |
5520, 7520, and 7720. The MPLS Feature is available as part of the Premier License. |
No |
| AVB Feature License |
All platforms, except 4120, 4220, 5320-XT, 7520, and 7720. All Universal Hardware platforms have the AVB Feature License included in the Base License. You do not need to separately purchase and install the AVB Feature License for supported Universal platforms. |
No |
Network Timing Feature License |
Precision Time Protocol End-to-End Transparent Clock (PTPv2) | 5520, 5720, 7520, and 7720 series switches with Premier license. | No |
MAC Security License |
MAC Security licensing. | No | |
ExtremeCloud™ IQ Agent |
ExtremeCloud IQ provides device discovery, basic monitoring, visibility into homogenous stacking, ability to configure an optional user-defined VR, and address of the server to connect to. For more information about ExtremeCloud IQ, go to https://www.extremenetworks.com/extremecloud-iq/. | See ExtremeCloud IQ Platform Support. | Yes |
| Platform | Ports | LRM/MACsec Adapter Required? |
| ExtremeSwitching 5320 | Supported on all front-panel ports except stacking ports. Not supported on model 5320-24T-4X-XT. | No |
| ExtremeSwitching 5420 | Supported on all front-panel ports except stacking ports. | No |
| ExtremeSwitching 5520 | Supported on all front-panel ports. Not supported on 5520-VIM-4X and 24X 10G ports. | No |
| ExtremeSwitching 5720 | Supported on all front-panel ports except stacking ports. | No |
| Extreme 7520-48YE-8CE | Supported on all front-panel ports. | No |
| Switch Series | Switch Models |
| 4120* |
4120-24MW-4Y 4120-48MW-4Y |
| 4220* |
4220-8X 4220-12P-4X 4220-12T-4X 4220-24P-4X 4220-24T-4X 4220-48P-4X 4220-48T-4X 4220-4MW-8P-4X 4220-4MW-20P-4X 4220-8MW-40P-4X |
5320-48T-8XE 5320-48P-8XE 5320-24T-8XE 5320-24P-8XE 5320-16P-4XE 5320-16P-4XE-DC 5320-24T-4X-XT 5320-24T-24S-4XE-XT |
5420F-8W-16P-4XE 5420F-24P-4XE 5420F-24S-4XE 5420F-24T-4XE 5420F-16MW-32P-4XE 5420F-16W-32P-4XE 5420F-48P-4XE 5420F-48P-4XL 5420F-48T-4XE 5420M-24T-4YE 5420M-24W-4YE 5420M-16MW-32P-4YE 5420M-48T-4YE 5420M-48W-4YE |
5520-24T 5520-24W 5520-48T 5520-48W 5520-12MW-36W 5520-24X 5520-48SE 5520-24T-ACDC-BASE 5520-48T-ACDC-BASE 5520-24X-ACDC-BASE 5520-48SE-ACDC-BASE |
5720-24MW 5720-24MXW 5720-48MW 5720-48MXW |
| Extreme Networks 7520 | 7520-48Y-8C 7520-48XT-6C 7520-48YE-8CE |
| Extreme Networks 7720 | 7720-32C |
* - See 4000 Series User Guide for this version of Switch Engine for detailed information on these Cloud-managed devices.
