Power Reserve Budget
Power supply equipment (PSEs) can be categorized as either Type 1, Type 2, Type 3, or Type 4
PSEs . Type 3 PSEs support powered devices (PDs) up to class 6. Type 4 PSEs support PDs up to
class 8.
4120 Series Switches
| Switch Model |
With Internal Fixed PSU |
With Internal Fixed PSU + 920W PSU |
With Internal Fixed PSU + 1200W PSU |
With Internal Fixed PSU + 2000W PSU |
| 4120-24MW-4Y (100-120VAC) |
680W |
1440W |
1380W |
Not Supported |
| 4120-48MW-4Y (100-120VAC) |
640W |
Not Supported |
1340W |
1230W |
| 4120-24MW-4Y (200-240VAC) |
680W |
1440W |
1540W |
Not Supported |
| 4120-48MW-4Y (200-240VAC) |
980W |
Not Supported |
1780W |
2180W |
4220 Series Switches
| Switch Model |
PoE Budget |
| 4220-12P-4X |
124W |
| 4220-24P-4X |
195W |
| 4220-48P-4X |
370W |
| 4220-4MW-8P-4X |
240W |
| 4220-4MW-20P-4X |
370W |
| 4220-8MW-40P-4X |
740W |
ExtremeSwitching 5320-24P Series Switches
ExtremeSwitching 5320-24P series
switches have the following power reserve budgets:
Table 1. ExtremeSwitching 5320-24P-8XE PoE Power Budget
| Single Internal Fixed PSU |
| 370W |
ExtremeSwitching 5320-48P Series Switches
ExtremeSwitching 5320-48P series
Table 2. ExtremeSwitching 5320-48P-8XE PoE Power Budget
| 740W |
ExtremeSwitching 5420F Series Switches
ExtremeSwitching 5420F series
Table 3. ExtremeSwitching 5420F-24P-4XE PoE Power Budget
Recommended Secondary PSU |
| 380W |
720W |
Table 4. ExtremeSwitching 5420F-48P-4XE PoE Power Budget
| 740W |
1480W |
Table 5. ExtremeSwitching 5420F-48P-4XL PoE Power Budget
| 740W |
1480W |
Table 6. ExtremeSwitching 5420F-8W-16P-4XE PoE Power
Budget
| 480W |
960W |
Table 7. ExtremeSwitching 5420F-16W-32P-4XE PoE Power
Budget
| 872W*/960W** |
1437W*/1874W** |
Table 8. ExtremeSwitching 5420F-16MW-32P-4XE PoE Power
Budget
| 860W*/960W** |
1425W*/1862W** |
* @ 100-120 VAC
** @ 200-240VAC
ExtremeSwitching 5420M Series Switches
ExtremeSwitching 5420M series
Table 9. ExtremeSwitching 5420M-24W-4YE PoE Power Budget
| 1 x 920W |
2 x 920W |
| 720W |
1440W |
Table 10. ExtremeSwitching 5420M-48W-4YE PoE Power Budget
| 1 x 920W |
2 x 920W |
1 x 2000W @ 100-120VAC |
1 x 2000W @ 200-240VAC |
1 x 920W & 1 x 2000W @100-120VAC |
1 x 920W & 1 x 2000W @ 200-240VAC |
2 x 2000W @ 100-120VAC |
2 x 2000W @ 200-240VAC |
| 804W |
1558W |
884W |
1440W |
1212W |
2076W |
1704W |
2880W |
Table 11. ExtremeSwitching 5420M-16MW-32P-4YE PoE Power
Budget
| 1 x 920W |
2 x 920W |
| 787W |
1541W |
867W |
1440W |
1195W |
2059W |
1687W |
2400W |
ExtremeSwitching 5520 Series Switches
ExtremeSwitching 5520 series
Table 12. ExtremeSwitching 5520-24W—System Power: 400W
| PSU1 |
PSU2 |
30W Ports |
60W Ports |
90W Ports |
PoE Max |
| 2,000W high line |
2,000W high line |
24 |
24 |
24 |
2,160W |
| 20,00W low line |
2,000W low line |
24 |
24 |
20 |
1,800W |
| 1,100W |
1,100W |
24 |
24 |
20 |
1,800W |
| 715W |
715W |
24 |
17 |
11 |
1,020W |
| 2,000W high line |
0W |
24 |
24 |
17 |
1,530W |
| 2,000W low line |
0W |
23 |
11 |
7 |
690W |
| 1,100W |
0W |
23 |
11 |
7 |
690W |
| 715W |
0W |
10 |
5 |
3 |
300W |
Table 13. ExtremeSwitching 5520-48W—System Power: 400W
| PSU1 |
PSU2 |
30W Ports |
60W Ports |
90W Ports |
PoE Max |
| 2,000W high line |
2,000W high line |
48 |
48 |
40 |
3,600W |
| 2,000W low line |
2,000W low line |
48 |
30 |
20 |
1,800W |
| 1,100W |
1,100W |
48 |
30 |
20 |
1,800W |
| 715W |
715W |
34 |
17 |
11 |
1,020W |
| 2,000W high line |
0W |
48 |
26 |
17 |
1,560W |
| 2,000W low line |
0W |
23 |
11 |
7 |
690W |
| 1,100W |
0W |
23 |
11 |
7 |
690W |
| 715W |
0W |
10 |
5 |
3 |
300W |
Table 14. ExtremeSwitching 5520-12MW-36W—System Power:
400W
| PSU1 |
PSU2 |
30W Ports |
60W Ports |
90W Ports |
PoE Max |
| 2,000W high line |
2,000W high line |
48 |
48 |
40 |
3,600W |
| 2,000W low line |
2,000W low line |
48 |
30 |
20 |
1,800W |
| 1,100W |
1,100W |
48 |
30 |
20 |
1,800W |
| 715W |
715W |
34 |
17 |
11 |
1,020W |
| 2,000W high line |
0W |
48 |
26 |
17 |
1,560W |
| 2,000W low line |
0W |
23 |
11 |
7 |
690W |
| 1,100W |
0W |
23 |
11 |
7 |
690W |
| 715W |
0W |
10 |
5 |
3 |
300W |
ExtremeSwitching 5720 Series Switches
ExtremeSwitching series switches have the following power reserve budgets:
Table 15. ExtremeSwitching 5720 PoE Power Budget
| Switch Model |
1 x 715W |
2 x 715W |
1 x 1100W |
2 x 1100W |
1 x 2000W @110-132VAC |
2 x 2000W @110-132VAC |
1 x 2000W @220-264VAC |
2 x 2000W @220-264VAC |
| 5720-24MW |
450W |
1093W |
835W |
1825W |
835W |
1825W |
1735W |
2160W |
| 5720-24MXW |
450W |
1093W |
835W |
1825W |
835W |
1825W |
1735W |
2160W |
| 5720-48MW |
450W |
1093W |
835W |
1825W |
835W |
1825W |
1735W |
3535W |
| 5720-48MXW |
450W |
1093W |
835W |
1825W |
835W |
1825W |
1735W |
3535W |
It‘s recommended that primary and secondary PSUs be of the same type to support optimal
PoE operation.
Guard Band
To reduce the chances of ports fluctuating between powered and
non-powered states, newly inserted PDs are not powered when the actual delivered power for
the switch is within a preset value below the configured inline power budget for that slot
or switch.
This band is called the guard band and the value used is 20 W for all ExtremeSwitching series switches.
However, actual aggregate power can be delivered up to the configured inline power budget
for the slot or switch (for example, when delivered power from ports increases or when the
configured inline power budget for the slot is reduced).
If total consumed power is within the guard band, new ports are not powered up.
