The following example shows how to use full automation, partial automation, or manual configuration to set up a redundant controlling bridge (CB) topology with three attached bridge port extenders (BPEs) in a two-tier structure (see Redundant CBs with Two-Tier BPEs Topology).
enable sharing 1:22 group 1:22,1:26 lacp create vlan isc tag 100 configure isc ipaddress 1.1.1.1/24 configure isc add port 1:22 tagged create mlag peer vpex_peer configure mlag peer vpex_peer ipaddress 1.1.1.2
enable sharing 1:22 group 1:22,1:26 lacp create vlan isc tag 100 configure isc ipaddress 1.1.1.2/24 configure isc add port 1:22 tagged create mlag peer vpex_peer configure mlag peer vpex_peer ipaddress 1.1.1.1
start orchestration mlag vpex_peer
The CLI prompt changes to inform you that you are in orchestration mode.Using orchestration mode enforces that all configuration commands are now checkpointed to the MLAG peer switch.
Slot-1 VPEX 5520.1 # enable sharing 1:10 group 1:10 lacp Slot-1 VPEX 5520.2 # enable sharing 1:20 group 1:20 lacp
enable mlag port 1:10 peer vpex_peer id 101 enable mlag port 1:20 peer vpex_peer id 102
configure mlag peer peer_name lacp-mac lacp_mac_address
configure mlag ports reload-delay <time> enable mlag port reload-delay
configure mlag ports link-up-isolation on
