The show switch management command displays whether or not CLI scripting is enabled, whether or not the configuration is persistent, and the CLI scripting error mode as shown in the following example:
# show switch management CLI idle timeout : Enabled (20 minutes) CLI max number of login attempts : 3 CLI max number of sessions : 8 CLI paging : Enabled CLI space-completion : Disabled (this session only) CLI configuration logging : Disabled (without expansion) CLI journal size : 100 CLI password prompting only : Disabled CLI display moved-keywords : Hidden CLI moved-keywords hidden release: 31.5 CLI RADIUS cmd authorize tokens : 2 CLI scripting : Disabled (this session only) CLI scripting error mode : Ignore-Error (this session only) CLI script search path : ".:/usr/local/cfg" (this session only) CLI persistent mode : Persistent (this session only) CLI prompting : Enabled (this session only) CLI screen size : 24 Lines 80 Columns (this session only) CLI refresh : Enabled CLI history expansion : Disabled Image integrity checking : Off Current system port notation : slot:port Configured system port notation : slot:port Telnet access : Enabled (tcp port 23 vr all) : Access Profile : not set SSH access : Disabled (Key invalid, tcp port 22 vr all) : Secure-Mode : Off : Access Profile : not set SSH2 idle time : 60 minutes SSH2 rekey interval : 4096 MB and no time limit Web access : Enabled (tcp port 80) : Access Profile : not set Total Read Only Communities : 0 Total Read Write Communities : 0 SNMP access : Disabled : Access Profile : not set SNMP Notifications : Enabled SNMP Notification Receivers : None SNMP stats: InPkts 0 OutPkts 0 Errors 0 AuthErrors 0 Gets 0 GetNexts 0 Sets 0 Drops 0 SNMP traps: Sent 0 AuthTraps Enabled SNMP inform: Sent 0 Retries 0 Failed 0 (pacman debug) Slot-1 switch_model-EXOS.2 #
