Where the following is true:
Output from this command includes the following information:
Total User/System CPU Usage—The amount of time recorded in seconds that the process spends occupying CPU resources. The values are cumulative meaning that the values are displayed as long as the system is running. You can use this information for debugging purposes to see where the process spends the most amount of time: user context or system context.
The following is sample truncated output from a switch:
5420F-48P-4XE.1 # show cpu-monitoring
CPU Utilization Statistics - Monitored every 5 seconds
Process 5 10 30 1 5 30 1 Max Total
secs secs secs min mins mins hour User/System
util util util util util util util util CPU Usage
(%) (%) (%) (%) (%) (%) (%) (%) (secs)
System 3.7 3.7 3.6 3.6 3.5 3.5 3.3 5.3 17.63 158657.42
aaa 0.0 0.0 0.0 0.0 0.0 0.0 0.0 1.0 15.55 18.87
acl 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.6 138.28 214.65
bfd 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.6 75.59 62.81
bgp 0.0 0.0 0.0 0.0 0.0 0.0 0.0 2.1 0.25 0.07
brm 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.3 0.06 0.03
cfgmgr 0.0 0.0 0.0 0.0 0.0 0.0 0.0 1.2 0.46 0.23
cli 0.0 0.1 0.0 0.0 0.0 0.0 0.0 16.0 10.05 3.42
devmgr 0.0 0.0 0.0 0.0 0.0 0.0 0.0 3.5 0.60 0.33
dirser 0.0 0.0 0.0 0.0 0.0 0.0 0.0 1.3 0.15 0.22
dosprotect 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.3 0.09 0.06
dot1ag 0.0 0.0 0.0 0.0 0.0 0.0 0.0 1.0 1.58 2.23
