You do not have the required software license:
If you attempt to execute a command and you do not have the required license, the switch returns the following message:
 Error: This command cannot be executed at the current license level.
You have reached the limits defined by the current software license level:
If you attempt to execute a command and you have reached the limits defined by the current license level the switch returns the following message:
 Error: You have reached the maximum limit for this feature at this license level.
For more information about licensing requirements, see the Switch Engine v33.1.1 Licensing Guide document.
