The following configuration example shows the Extreme Networks switch configuration needed to support the MAC-based network login example.
create vlan “temp” create vlan “corp” configure vlan “default” delete ports 4:1-4:4 # Configuration Information for VLAN corp # No VLAN-ID is associated with VLAN corp. configure vlan “corp” ipaddress 10.203.0.224 255.255.255.0 # Network Login Configuration configure netlogin vlan “temp” enable netlogin mac enable netlogin ports 4:1-4:4 mac configure netlogin add mac-list default <password> # RADIUS Client Configuration configure radius netlogin primary server 10.0.1.2 1812 client-ip 10.10.20.30 vr “VR-Mgmt” configure radius netlogin primary shared-secret purple enable radius
The following example is a user's file entry for a specific MAC address on a FreeRADIUS server:
00E018A8C540 Auth-Type := Local, User-Password == "00E018A8C540"
For information about how to use and configure your RADIUS server, refer to Configuring the RADIUS Client and the documentation that came with your RADIUS server.
