By specifying information and detail, the output displays the temporarily added VLANs in network login MAC-based mode.
This command will also show port information for ingress filtering for MAC-based VLANs.
VLAN cfg—The term "MAC-based" appears next to the tag number.
Netlogin port mode—This output was added to display the port mode of operation. "Mac-based" appears and the network login port mode of operation.
By specifying detail, the output displays detailed information including the ports associated with the VLAN.
If network login is enabled together with STP, the 'a' and 'u' flags are controlled by network login only when the STP port state is ‘Forwarding.‘
