EVPN with eBGP between leaf and spine. Spines are on a dedicated ASn, Each leaf is on separate ASn. MLAG peers share ASn.
create bgp EVPN instance evi_1 configure bgp EVPN instance evi_1 VXLAN vni 100 create bgp EVPN instance evi_2 configure bgp EVPN instance evi_2 VXLAN vni 200 configure bgp EVPN instance evi_1 route-target both add 100:100 configure bgp EVPN instance evi_2 route-target both add 200:200
On SLX and other platforms “retain route-targets” should be enabled on spine/transit L3 nodes. ExtremeXOS by default retains all RTs and does not have a command to turn it off.# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-36 configure vr VR-Default add ports 1-36 configure vlan default delete ports 1,4-5,7,16,19,21 enable jumbo-frame ports all create vlan "isc" configure vlan isc tag 4000 create vlan "loop" enable loopback-mode vlan loop create vlan "mlagvtep" enable loopback-mode vlan mlagvtep create vlan "tenant" configure vlan tenant tag 10 configure vlan tenant suppress arp-only create vlan "trunk1_2" configure vlan trunk1_2 tag 4001 create vlan "trunk1_3" create vlan "trunk1_4" create vlan "untagtenant" configure vlan untagtenant suppress arp-only configure ports 1 auto off speed 10000 duplex full configure ports 2 auto off speed 10000 duplex full configure ports 3 auto off speed 10000 duplex full configure ports 4 auto off speed 10000 duplex full configure ports 5 auto off speed 10000 duplex full configure ports 6 auto off speed 10000 duplex full configure ports 7 auto off speed 10000 duplex full configure ports 8 auto off speed 10000 duplex full configure ports 9 auto off speed 10000 duplex full configure ports 10 auto off speed 10000 duplex full configure ports 11 auto off speed 10000 duplex full configure ports 12 auto off speed 10000 duplex full configure ports 13 auto off speed 10000 duplex full configure ports 14 auto off speed 10000 duplex full configure ports 15 auto off speed 10000 duplex full configure ports 16 auto off speed 10000 duplex full configure ports 17 auto off speed 10000 duplex full configure ports 18 auto off speed 10000 duplex full configure ports 19 auto off speed 10000 duplex full configure ports 20 auto off speed 10000 duplex full configure ports 21 auto off speed 10000 duplex full configure ports 22 auto off speed 10000 duplex full configure ports 23 auto off speed 10000 duplex full configure ports 24 auto off speed 10000 duplex full configure ports 26 auto off speed 10000 duplex full configure ports 27 auto off speed 10000 duplex full configure ports 28 auto off speed 10000 duplex full enable sharing 1 grouping 1 algorithm address-based L2 lacp configure vlan Default add ports 2-3,6,8-15,17-18,20,22-36 untagged configure vlan isc add ports 21 tagged configure vlan tenant add ports 1,16,21 tagged configure vlan trunk1_2 add ports 21 tagged configure vlan trunk1_3 add ports 5 untagged configure vlan trunk1_4 add ports 7 untagged configure vlan untagtenant add ports 1,16,21 untagged configure vlan isc ipaddress 172.16.1.0 255.255.255.254 configure vlan loop ipaddress 1.1.1.1 255.255.255.255 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.16.27 255.255.255.0 configure vlan mlagvtep ipaddress 1.1.1.200 255.255.255.255 enable ipforwarding vlan mlagvtep configure vlan tenant ipaddress 10.1.100.100 255.255.255.0 enable ipforwarding vlan tenant configure vlan trunk1_2 ipaddress 192.168.5.0 255.255.255.254 enable ipforwarding vlan trunk1_2 configure vlan trunk1_3 ipaddress 192.168.1.0 255.255.255.254 enable ipforwarding vlan trunk1_3 configure vlan trunk1_4 ipaddress 192.168.2.0 255.255.255.254 enable ipforwarding vlan trunk1_4 configure vlan untagtenant ipaddress 20.1.100.100 255.255.255.0 enable ipforwarding vlan untagtenant # # Module mcmgr configuration. # disable igmp snooping vlan "tenant" disable igmp snooping vlan "untagtenant" # # Module vsm configuration. # create mlag peer "leaf2" configure mlag peer "leaf2" ipaddress 172.16.1.1 vr VR-Default configure mlag peer "leaf2" lacp-mac 00:00:de:ad:be:ef enable mlag port 1 peer "leaf2" id 1 # # Module bgp configuration. # configure bgp AS-number 10000 configure bgp routerid 1.1.1.1 configure bgp maximum-paths 2 enable bgp fast-external-fallover configure bgp add network 1.1.1.1/32 configure bgp add network 1.1.1.200/32 create bgp neighbor 192.168.1.1 remote-AS-number 20000 enable bgp neighbor 192.168.1.1 create bgp neighbor 192.168.2.1 remote-AS-number 20000 enable bgp neighbor 192.168.2.1 create bgp neighbor 192.168.5.1 remote-AS-number 10000 enable bgp neighbor 192.168.5.1 configure bgp neighbor 192.168.1.1 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.1.1 capability l2vpn-EVPN configure bgp neighbor 192.168.2.1 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.2.1 capability l2vpn-EVPN configure bgp neighbor 192.168.5.1 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.5.1 capability l2vpn-EVPN enable bgp export direct address-family ipv4-unicast enable bgp create bgp EVPN instance evi_1 configure bgp EVPN instance evi_1 VXLAN vni 100 create bgp EVPN instance evi_2 configure bgp EVPN instance evi_2 VXLAN vni 200 configure bgp EVPN instance evi_1 route-target both add 100:100 configure bgp EVPN instance evi_2 route-target both add 200:200 # # Module otm configuration. # configure virtual-network local-endpoint ipaddress 1.1.1.200 vr "VR-Default" create virtual-network "vni1" flooding standard configure virtual-network "vni1" VXLAN vni 100 configure virtual-network "vni1" add vlan tenant create virtual-network "vni2" flooding standard configure virtual-network "vni2" VXLAN vni 200 configure virtual-network "vni2" add vlan untagtenant
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-72 configure vr VR-Default add ports 1-72 configure vlan default delete ports 1-72 enable jumbo-frame ports all create vlan "isc" configure vlan isc tag 4000 create vlan "loop" enable loopback-mode vlan loop create vlan "loop2" enable loopback-mode vlan loop2 create vlan "mlagvtep" enable loopback-mode vlan mlagvtep create vlan "tenant" configure vlan tenant tag 10 configure vlan tenant suppress arp-only create vlan "trunk1_2" configure vlan trunk1_2 tag 4001 create vlan "trunk2_3" create vlan "trunk2_4" create vlan "untagtenant" configure vlan untagtenant suppress arp-only configure ports 50 auto off speed 10000 duplex full configure ports 51 auto off speed 10000 duplex full configure ports 52 auto off speed 10000 duplex full enable sharing 53 grouping 53-56 algorithm address-based L2 lacp configure vlan isc add ports 66 tagged configure vlan tenant add ports 4-5,53,66 tagged configure vlan trunk1_2 add ports 66 tagged configure vlan trunk2_3 add ports 57 untagged configure vlan trunk2_4 add ports 49 untagged configure vlan untagtenant add ports 4-5,53,66 untagged configure vlan isc ipaddress 172.16.1.1 255.255.255.254 configure vlan loop ipaddress 2.2.2.2 255.255.255.255 enable ipforwarding vlan loop configure vlan loop2 ipaddress 2.2.2.100 255.255.255.255 enable ipforwarding vlan loop2 configure vlan Mgmt ipaddress 10.127.16.19 255.255.255.0 configure vlan mlagvtep ipaddress 1.1.1.200 255.0.0.0 enable ipforwarding vlan mlagvtep configure vlan tenant ipaddress 10.1.100.100 255.255.255.0 enable ipforwarding vlan tenant configure vlan trunk1_2 ipaddress 192.168.5.1 255.255.255.254 enable ipforwarding vlan trunk1_2 configure vlan trunk2_3 ipaddress 192.168.3.0 255.255.255.254 enable ipforwarding vlan trunk2_3 configure vlan trunk2_4 ipaddress 192.168.4.0 255.255.255.254 enable ipforwarding vlan trunk2_4 configure vlan untagtenant ipaddress 20.1.100.100 255.255.255.0 enable ipforwarding vlan untagtenant # # Module mcmgr configuration. # disable igmp snooping vlan "tenant" disable igmp snooping vlan "untagtenant" # # Module otm configuration. # configure virtual-network local-endpoint ipaddress 1.1.1.200 vr "VR-Default" create virtual-network "vni1" flooding standard configure virtual-network "vni1" VXLAN vni 100 configure virtual-network "vni1" add vlan tenant create virtual-network "vni2" flooding standard configure virtual-network "vni2" VXLAN vni 200 configure virtual-network "vni2" add vlan untagtenant # # Module bgp configuration. # # configure bgp AS-number 10000 configure bgp routerid 2.2.2.2 configure bgp maximum-paths 2 enable bgp fast-external-fallover configure bgp add network 1.1.1.200/32 configure bgp add network 2.2.2.2/32 create bgp neighbor 192.168.3.1 remote-AS-number 20000 enable bgp neighbor 192.168.3.1 create bgp neighbor 192.168.4.1 remote-AS-number 20000 enable bgp neighbor 192.168.4.1 create bgp neighbor 192.168.5.0 remote-AS-number 10000 enable bgp neighbor 192.168.5.0 configure bgp neighbor 192.168.3.1 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.3.1 capability l2vpn-EVPN configure bgp neighbor 192.168.4.1 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.4.1 capability l2vpn-EVPN configure bgp neighbor 192.168.5.0 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.5.0 capability l2vpn-EVPN enable bgp export direct address-family ipv4-unicast enable bgp create bgp EVPN instance evi_1 configure bgp EVPN instance evi_1 VXLAN vni 100 create bgp EVPN instance evi_2 configure bgp EVPN instance evi_2 VXLAN vni 200 configure bgp EVPN instance evi_1 route-target both add 100:100 configure bgp EVPN instance evi_2 route-target both add 200:200 # Module vrrp configuration. # create vrrp vlan tenant vrid 1 configure vrrp vlan tenant vrid 1 priority 255 create vrrp vlan untagtenant vrid 1 configure vrrp vlan untagtenant vrid 1 priority 255 configure vrrp vlan tenant vrid 1 add 10.1.100.100 configure vrrp vlan untagtenant vrid 1 add 20.1.100.100 enable vrrp vlan tenant vrid 1 enable vrrp vlan untagtenant vrid 1 # # Module vsm configuration. # create mlag peer "leaf1" configure mlag peer "leaf1" ipaddress 172.16.1.0 vr VR-Default configure mlag peer "leaf1" lacp-mac 00:00:de:ad:be:ef enable mlag port 53 peer "leaf1" id 1
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-56 configure vr VR-Default add ports 1-56 configure vlan default delete ports 1,50-51 enable jumbo-frame ports all create vlan "leaf3_trunk1" create vlan "leaf3_trunk2" create vlan "loop" enable loopback-mode vlan loop create vlan "tenant" configure vlan tenant tag 10 configure vlan tenant suppress arp-only create vlan "untagtenant" configure vlan untagtenant suppress arp-only configure ports 49 auto off speed 10000 duplex full configure ports 50 auto off speed 10000 duplex full configure ports 51 auto off speed 10000 duplex full configure ports 52 auto off speed 10000 duplex full configure ports 54 auto off speed 10000 duplex full configure ports 55 auto off speed 10000 duplex full configure ports 56 auto off speed 10000 duplex full configure vlan Default add ports 2-49,52-56 untagged configure vlan leaf3_trunk1 add ports 51 untagged configure vlan leaf3_trunk2 add ports 50 untagged configure vlan tenant add ports 1 tagged configure vlan untagtenant add ports 1 untagged configure vlan leaf3_trunk1 ipaddress 192.168.6.0 255.255.255.254 enable ipforwarding vlan leaf3_trunk1 configure vlan leaf3_trunk2 ipaddress 192.168.7.0 255.255.255.254 enable ipforwarding vlan leaf3_trunk2 configure vlan loop ipaddress 5.5.5.5 255.255.255.255 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.16.17 255.255.255.0 configure vlan tenant ipaddress 10.1.100.100 255.255.255.0 enable ipforwarding vlan tenant configure vlan untagtenant ipaddress # Module mcmgr configuration. # disable igmp snooping vlan "tenant" disable igmp snooping vlan "untagtenant" # # Module otm configuration. # configure virtual-network local-endpoint ipaddress 5.5.5.5 vr "VR-Default" create virtual-network "vni1" flooding standard configure virtual-network "vni1" VXLAN vni 100 configure virtual-network "vni1" add vlan tenant create virtual-network "vni2" flooding standard configure virtual-network "vni2" VXLAN vni 200 configure virtual-network "vni2" add vlan untagtenant # # Module bgp configuration. # configure bgp AS-number 30000 configure bgp routerid 5.5.5.5 configure bgp maximum-paths 2 enable bgp fast-external-fallover configure bgp restart both configure bgp add network 5.5.5.5/32 create bgp neighbor 192.168.6.1 remote-AS-number 20000 enable bgp neighbor 192.168.6.1 create bgp neighbor 192.168.7.1 remote-AS-number 20000 enable bgp neighbor 192.168.7.1 configure bgp neighbor 192.168.6.1 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.6.1 capability l2vpn-EVPN configure bgp neighbor 192.168.7.1 allowas-in max-as-occurrence 3 enable bgp neighbor 192.168.7.1 capability l2vpn-EVPN enable bgp create bgp EVPN instance evi_1 configure bgp EVPN instance evi_1 VXLAN vni 100 create bgp EVPN instance evi_2 configure bgp EVPN instance evi_2 VXLAN vni 200 configure bgp EVPN instance evi_1 route-target both add 100:100 configure bgp EVPN instance evi_2 route-target both add 200:200 # # Module vrrp configuration. # create vrrp vlan tenant vrid 1 configure vrrp vlan tenant vrid 1 priority 255 create vrrp vlan untagtenant vrid 1 configure vrrp vlan untagtenant vrid 1 priority 255 configure vrrp vlan tenant vrid 1 add 10.1.100.100 configure vrrp vlan untagtenant vrid 1 add 20.1.100.100 enable vrrp vlan tenant vrid 1 enable vrrp vlan untagtenant vrid 1
configure vlan default delete ports all configure vr VR-Default delete ports 1-128 configure vr VR-Default add ports 1-128 configure vlan default delete ports 33,57,89,105 enable jumbo-frame ports all create vlan "leaf3_trunk1" create vlan "loop" enable loopback-mode vlan loop create vlan "routed" configure vlan routed tag 4030 create vlan "trunk1_3" create vlan "trunk2_3" configure vlan Default add ports 1-32,34-56,58-88,90-104,106-128 untagged configure vlan leaf3_trunk1 add ports 89 untagged configure vlan routed add ports 33 tagged configure vlan trunk1_3 add ports 57 untagged configure vlan trunk2_3 add ports 105 untagged configure vlan leaf3_trunk1 ipaddress 192.168.6.1 255.255.255.254 enable ipforwarding vlan leaf3_trunk1 configure vlan loop ipaddress 3.3.3.100 255.0.0.0 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.16.24 255.255.255.0 configure vlan routed ipaddress 172.16.1.1 255.255.255.0 enable ipforwarding vlan routed configure vlan trunk1_3 ipaddress 192.168.1.1 255.255.255.254 enable ipforwarding vlan trunk1_3 configure vlan trunk2_3 ipaddress 192.168.3.1 255.255.255.254 enable ipforwarding vlan trunk2_3 # # Module bgp configuration. # # configure bgp AS-number 20000 configure bgp routerid 3.3.3.3 configure bgp maximum-paths 2 enable bgp fast-external-fallover create bgp neighbor 192.168.1.0 remote-AS-number 10000 enable bgp neighbor 192.168.1.0 create bgp neighbor 192.168.3.0 remote-AS-number 10000 enable bgp neighbor 192.168.3.0 create bgp neighbor 192.168.6.0 remote-AS-number 30000 enable bgp neighbor 192.168.6.0 enable bgp neighbor 192.168.1.0 capability l2vpn-EVPN enable bgp neighbor 192.168.1.0 address-family l2vpn-EVPN next-hop-unchanged enable bgp neighbor 192.168.3.0 capability l2vpn-EVPN enable bgp neighbor 192.168.3.0 address-family l2vpn-EVPN next-hop-unchanged enable bgp neighbor 192.168.6.0 capability l2vpn-EVPN enable bgp neighbor 192.168.6.0 address-family l2vpn-EVPN next-hop-unchanged enable bgp export ospf-extern1 address-family ipv4-unicast enable bgp export ospf-extern2 address-family ipv4-unicast enable bgp export ospf-inter address-family ipv4-unicast enable bgp export ospf-intra address-family ipv4-unicast enable bgp # Module ospf configuration. # enable ospf configure ospf add vlan routed area 0.0.0.0
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-64 configure vr VR-Default add ports 1-64 configure vlan default delete ports 25,27,49 create vlan "leaf3_trunk2" create vlan "loop" enable loopback-mode vlan loop create vlan "trunk1_4" create vlan "trunk2_4" configure ports 1 auto off speed 10000 duplex full configure ports 2 auto off speed 10000 duplex full configure ports 3 auto off speed 10000 duplex full configure ports 4 auto off speed 10000 duplex full configure ports 5 auto off speed 10000 duplex full configure ports 6 auto off speed 10000 duplex full configure ports 7 auto off speed 10000 duplex full configure ports 8 auto off speed 10000 duplex full configure ports 9 auto off speed 10000 duplex full configure ports 10 auto off speed 10000 duplex full configure ports 11 auto off speed 10000 duplex full configure ports 12 auto off speed 10000 duplex full configure ports 13 auto off speed 10000 duplex full configure ports 14 auto off speed 10000 duplex full configure ports 15 auto off speed 10000 duplex full configure ports 16 auto off speed 10000 duplex full configure ports 17 auto off speed 10000 duplex full configure ports 18 auto off speed 10000 duplex full configure ports 19 auto off speed 10000 duplex full configure ports 20 auto off speed 10000 duplex full configure ports 21 auto off speed 10000 duplex full configure ports 22 auto off speed 10000 duplex full configure ports 23 auto off speed 10000 duplex full configure ports 24 auto off speed 10000 duplex full configure ports 25 auto off speed 10000 duplex full configure ports 26 auto off speed 10000 duplex full configure ports 27 auto off speed 10000 duplex full configure ports 28 auto off speed 10000 duplex full configure ports 29 auto off speed 10000 duplex full configure ports 30 auto off speed 10000 duplex full configure ports 31 auto off speed 10000 duplex full configure ports 32 auto off speed 10000 duplex full configure ports 33 auto off speed 10000 duplex full configure ports 34 auto off speed 10000 duplex full configure ports 35 auto off speed 10000 duplex full configure ports 36 auto off speed 10000 duplex full configure ports 37 auto off speed 10000 duplex full configure ports 38 auto off speed 10000 duplex full configure ports 39 auto off speed 10000 duplex full configure ports 40 auto off speed 10000 duplex full configure ports 41 auto off speed 10000 duplex full configure ports 42 auto off speed 10000 duplex full configure ports 43 auto off speed 10000 duplex full configure ports 44 auto off speed 10000 duplex full configure ports 45 auto off speed 10000 duplex full configure ports 46 auto off speed 10000 duplex full configure ports 47 auto off speed 10000 duplex full configure ports 48 auto off speed 10000 duplex full configure vlan Default add ports 1-24,26,28-48,50-64 untagged configure vlan leaf3_trunk2 add ports 25 untagged configure vlan trunk1_4 add ports 27 untagged configure vlan trunk2_4 add ports 49 untagged configure vlan leaf3_trunk2 ipaddress 192.168.7.1 255.255.255.254 enable ipforwarding vlan leaf3_trunk2 configure vlan loop ipaddress 4.4.4.4 255.255.255.255 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.13.10 255.255.255.0 configure vlan trunk1_4 ipaddress 192.168.2.1 255.255.255.254 enable ipforwarding vlan trunk1_4 configure vlan trunk2_4 ipaddress 192.168.4.1 255.255.255.254 enable ipforwarding vlan trunk2_4 # # Module bgp configuration. # configure bgp AS-number 20000 configure bgp routerid 4.4.4.4 configure bgp maximum-paths 2 enable bgp fast-external-fallover configure bgp add network 3.3.3.100/32 configure bgp add network 4.4.4.4/32 create bgp neighbor 192.168.2.0 remote-AS-number 10000 enable bgp neighbor 192.168.2.0 create bgp neighbor 192.168.4.0 remote-AS-number 10000 enable bgp neighbor 192.168.4.0 create bgp neighbor 192.168.7.0 remote-AS-number 30000 enable bgp neighbor 192.168.7.0 enable bgp neighbor 192.168.2.0 capability l2vpn-EVPN enable bgp neighbor 192.168.2.0 address-family l2vpn-EVPN next-hop-unchanged enable bgp neighbor 192.168.4.0 capability l2vpn-EVPN enable bgp neighbor 192.168.4.0 address-family l2vpn-EVPN next-hop-unchanged enable bgp neighbor 192.168.7.0 capability l2vpn-EVPN enable bgp neighbor 192.168.7.0 address-family l2vpn-EVPN next-hop-unchanged enable bgp export ospf-extern1 address-family ipv4-unicast enable bgp export ospf-extern2 address-family ipv4-unicast enable bgp
Verify BGP Adjacency
Leaf1.21 # show bgp neighbor
Peer AS Weight State InMsgs OutMsgs(InQ) Up/Down
Ee-- 192.168.1.1 20000 1 ESTABLISHED 45 62 (0 ) 0:0:08:40
Ee-- 192.168.2.1 20000 1 ESTABLISHED 27 74 (0 ) 0:0:08:50
Ie-- 192.168.5.1 10000 1 ESTABLISHED 57 60 (0 ) 0:0:08:35
Leaf2.10 # show bgp neighbor
Ee-- 192.168.3.1 20000 1 ESTABLISHED 75 64 (0 ) 0:0:09:08
Ee-- 192.168.4.1 20000 1 ESTABLISHED 64 77 (0 ) 0:0:09:01
Ie-- 192.168.5.0 10000 1 ESTABLISHED 61 58 (0 ) 0:0:09:04
Leaf3.11 # show bgp neighbor
Ee-- 192.168.6.1 20000 1 ESTABLISHED 57 36 (0 ) 0:0:09:22
Ee-- 192.168.7.1 20000 1 ESTABLISHED 50 73 (0 ) 0:0:09:14
Spine1.2 # show bgp neighbor
Ee-- 192.168.1.0 10000 1 ESTABLISHED 63 46 (0 ) 0:0:09:36
Ee-- 192.168.3.0 10000 1 ESTABLISHED 64 76 (0 ) 0:0:09:35
Ee-- 192.168.6.0 30000 1 ESTABLISHED 37 57 (0 ) 0:0:09:35
Flags: (d) disabled, (e) enabled, (E) external peer, (I) internal peer
(m) EBGP multihop, (r) route reflector client
BGP Peer Statistics
Total Peers : 3
EBGP Peers : 3 IBGP Peers : 0
RR Client : 0 EBGP Multihop : 0
Enabled : 3 Disabled : 0
Spine2.14 # show bgp neighbor
Ee-- 192.168.2.0 10000 1 ESTABLISHED 234 186 (0 ) 0:0:10:00
Ee-- 192.168.4.0 10000 1 ESTABLISHED 218 244 (0 ) 0:0:09:42
Ee-- 192.168.7.0 30000 1 ESTABLISHED 146 134 (0 ) 0:0:09:41
BGP Peer Statistics
Total Peers : 3
Verify Type 2 MAC Routes
Leaf1.5 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- R 10 00:00:00:1c:7e:60 3.3.3.100 100 Yes R 10 00:00:00:47:ce:72 5.5.5.5 100 Yes L 10 00:00:0b:cb:21:a4 100 Yes L 10 00:00:0c:14:88:4b 100 Yes L 10 00:00:0c:34:c1:ed 100 Yes L 10 00:04:96:9d:42:32 100 Yes L 10 00:04:96:a3:fb:b0 100 Yes R 10 00:11:88:ff:04:74 5.5.5.5 100 Yes L 4087 00:00:00:1c:7e:5f 200 Yes R 4087 00:00:00:1c:7e:61 3.3.3.100 200 Yes R 4087 00:00:00:47:ce:73 5.5.5.5 200 Yes L 4087 00:00:04:d6:4d:6e 200 Yes L 4087 00:00:04:d6:4d:6f 200 Yes L 4087 00:04:96:9d:42:32 200 Yes L 4087 00:04:96:a3:fb:b0 200 Yes R 4087 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 16 Leaf2.5 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- R 10 00:00:00:1c:7e:60 3.3.3.100 100 Yes R 10 00:00:00:47:ce:72 5.5.5.5 100 Yes L 10 00:00:0b:cb:21:a4 100 Yes L 10 00:00:0c:14:88:4b 100 Yes L 10 00:00:0c:34:c1:ed 100 Yes L 10 00:04:96:9d:42:32 100 Yes L 10 00:04:96:a3:fb:b0 100 Yes R 10 00:11:88:ff:04:74 5.5.5.5 100 Yes L 4088 00:00:00:1c:7e:5f 200 Yes R 4088 00:00:00:1c:7e:61 3.3.3.100 200 Yes R 4088 00:00:00:47:ce:73 5.5.5.5 200 Yes L 4088 00:00:04:d6:4d:6e 200 Yes L 4088 00:00:04:d6:4d:6f 200 Yes L 4088 00:04:96:9d:42:32 200 Yes L 4088 00:04:96:a3:fb:b0 200 Yes R 4088 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 16 Leaf3.12 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- R 10 00:00:00:1c:7e:60 3.3.3.100 100 Yes L 10 00:00:00:47:ce:72 100 Yes R 10 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 00:04:96:a3:fb:b0 1.1.1.200 100 Yes L 10 00:11:88:ff:04:74 100 Yes R 4090 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4090 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4090 00:00:00:1c:7e:61 3.3.3.100 200 Yes L 4090 00:00:00:47:ce:73 200 Yes R 4090 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4090 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4090 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4090 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4090 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4090 00:04:96:a3:fb:b0 1.1.1.200 200 Yes L 4090 00:11:88:ff:04:74 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 21 Spine1.7 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- L 10 00:00:00:1c:7e:60 100 Yes R 10 00:00:00:47:ce:72 5.5.5.5 100 Yes R 10 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 00:04:96:a3:fb:b0 1.1.1.200 100 Yes R 10 00:11:88:ff:04:74 5.5.5.5 100 Yes R 4091 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4091 00:00:00:1c:7e:5f 1.1.1.200 200 Yes L 4091 00:00:00:1c:7e:61 200 Yes R 4091 00:00:00:47:ce:73 5.5.5.5 200 Yes R 4091 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4091 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4091 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4091 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4091 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4091 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4091 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 21
Leaf1.6 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ R 10 10.1.100.3 00:00:00:1c:7e:60 3.3.3.100 100 Yes R 10 10.1.100.6 00:00:00:47:ce:72 5.5.5.5 100 Yes L 10 10.1.100.1 00:00:0b:cb:21:a4 100 Yes L 10 10.1.100.5 00:00:0c:14:88:4b 100 Yes L 10 10.1.100.100 00:04:96:a3:fb:b0 100 Yes R 10 10.1.100.100 00:11:88:ff:04:74 5.5.5.5 100 Yes L 4087 20.1.100.5 00:00:00:1c:7e:5f 200 Yes R 4087 20.1.100.3 00:00:00:1c:7e:61 3.3.3.100 200 Yes R 4087 20.1.100.6 00:00:00:47:ce:73 5.5.5.5 200 Yes L 4087 20.1.100.1 00:00:04:d6:4d:6e 200 Yes L 4087 20.1.100.2 00:00:04:d6:4d:6f 200 Yes L 4087 20.1.100.100 00:04:96:a3:fb:b0 200 Yes R 4087 20.1.100.100 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in IP ARP cache. Total MAC/IP entries displayed: 13 Leaf2.6 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ R 10 10.1.100.3 00:00:00:1c:7e:60 3.3.3.100 100 Yes R 10 10.1.100.6 00:00:00:47:ce:72 5.5.5.5 100 Yes L 10 10.1.100.1 00:00:0b:cb:21:a4 100 Yes L 10 10.1.100.5 00:00:0c:14:88:4b 100 Yes L 10 10.1.100.2 00:00:0c:34:c1:ed 100 Yes L 10 10.1.100.100 00:04:96:9d:42:32 100 Yes R 10 10.1.100.100 00:11:88:ff:04:74 5.5.5.5 100 Yes L 4088 20.1.100.5 00:00:00:1c:7e:5f 200 Yes R 4088 20.1.100.3 00:00:00:1c:7e:61 3.3.3.100 200 Yes R 4088 20.1.100.6 00:00:00:47:ce:73 5.5.5.5 200 Yes L 4088 20.1.100.1 00:00:04:d6:4d:6e 200 Yes L 4088 20.1.100.2 00:00:04:d6:4d:6f 200 Yes L 4088 20.1.100.100 00:04:96:9d:42:32 200 Yes R 4088 20.1.100.100 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in IP ARP cache. Total MAC/IP entries displayed: 14 Leaf3.13 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ R 10 10.1.100.3 00:00:00:1c:7e:60 3.3.3.100 100 Yes L 10 10.1.100.6 00:00:00:47:ce:72 100 Yes R 10 10.1.100.1 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 10.1.100.5 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 10.1.100.2 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 100 Yes L 10 10.1.100.100 00:11:88:ff:04:74 100 Yes R 4090 20.1.100.5 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4090 20.1.100.5 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4090 20.1.100.3 00:00:00:1c:7e:61 3.3.3.100 200 Yes L 4090 20.1.100.6 00:00:00:47:ce:73 200 Yes R 4090 20.1.100.1 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4090 20.1.100.1 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4090 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 20.1.100.100 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4090 20.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 200 Yes L 4090 20.1.100.100 00:11:88:ff:04:74 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in IP ARP cache. Total MAC/IP entries displayed: 19 Spine1.13 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ L 10 10.1.100.3 00:00:00:1c:7e:60 100 Yes R 10 10.1.100.6 00:00:00:47:ce:72 5.5.5.5 100 Yes R 10 10.1.100.1 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 10.1.100.5 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 10.1.100.2 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 100 Yes R 10 10.1.100.100 00:11:88:ff:04:74 5.5.5.5 100 Yes R 4091 20.1.100.5 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4091 20.1.100.5 00:00:00:1c:7e:5f 1.1.1.200 200 Yes L 4091 20.1.100.3 00:00:00:1c:7e:61 200 Yes R 4091 20.1.100.6 00:00:00:47:ce:73 5.5.5.5 200 Yes R 4091 20.1.100.1 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4091 20.1.100.1 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4091 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 20.1.100.100 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4091 20.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4091 20.1.100.100 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in IP ARP cache. Total MAC/IP entries displayed: 19
Verify ARP and FDB Entries
Leaf1.7 # show iparp
VR Destination Mac Age Static VLAN VID Port
VR-Default 10.1.100.1 00:00:0b:cb:21:a4 17 NO tenant 10 16
VR-Default 10.1.100.5 00:00:0c:14:88:4b 7 NO tenant 10 1
VR-Default 10.1.100.6 00:00:00:47:ce:72 0 YES tenant 10 VR-Default:5.5.5.5
VR-Default 192.168.1.1 00:04:96:9c:2d:24 20 NO trunk1_3 4089 5
VR-Default 192.168.2.1 00:04:96:9b:b7:c9 20 NO trunk1_4 4088 7
VR-Default 20.1.100.1 00:00:04:d6:4d:6e 12 NO untagtenant 4087 16
VR-Default 20.1.100.2 00:00:04:d6:4d:6f 7 NO untagtenant 4087 21
VR-Default 20.1.100.5 00:00:00:1c:7e:5f 7 NO untagtenant 4087 1
VR-Default 20.1.100.6 00:00:00:47:ce:73 0 YES untagtenant 4087 VR-Default:5.5.5.5
VR-Default 192.168.5.1 00:04:96:9d:42:32 20 NO trunk1_2 4001 21
VR-Default 172.16.1.1 00:04:96:9d:42:32 20 NO isc 4000 21
Dynamic Entries : 9 Static Entries : 2
Pending Entries : 0
ARP address check: Enabled ARP refresh : Enabled
Timeout : 20 minutes ARP Sender-Mac Learning : Disabled
Locktime : 1000 milliseconds
Retransmit Time : 1000 milliseconds
Reachable Time : 900000 milliseconds (Auto)
Fast Convergence : Off
ARP Global Settings
Max Entries : 12288
Max Pending Entries : 256
Max Proxy Entries : 256
Leaf1.8 # show fdb
MAC VLAN Name( Tag) Age Flags Port / Virtual Port List
00:00:00:1c:7e:5f untagtenant(4087) 0000 d mi S 1
00:00:00:47:ce:72 tenant(0010) 0000 s m SXE VR-Default:5.5.5.5
00:00:00:47:ce:73 untagtenant(4087) 0000 s m SXE VR-Default:5.5.5.5
00:00:04:d6:4d:6e untagtenant(4087) 0000 d mi 16
00:00:04:d6:4d:6f untagtenant(4087) 0000 d mi S 21
00:00:0b:cb:21:a4 tenant(0010) 0000 d mi 16
00:00:0c:14:88:4b tenant(0010) 0000 d mi S 1
00:00:0c:34:c1:ed tenant(0010) 0078 d m S 21
00:04:96:9b:b7:c9 trunk1_4(4088) 0000 d mi 7
00:04:96:9c:2d:24 trunk1_3(4089) 0000 d mi 5
00:04:96:9d:42:32 tenant(0010) 0000 s m S 21
00:04:96:9d:42:32 untagtenant(4087) 0000 s m S 21
00:04:96:9d:42:32 trunk1_2(4001) 0000 s m S 21
00:04:96:9d:42:32 isc(4000) 0000 s m S 21
00:11:88:ff:04:74 tenant(0010) 0000 s m SXE VR-Default:5.5.5.5
00:11:88:ff:04:74 untagtenant(4087) 0000 s m SXE VR-Default:5.5.5.5
Flags : d - Dynamic, s - Static, p - Permanent, n - NetLogin, m - MAC, i - IP,
x - IPX, l - lockdown MAC, L - lockdown-timeout MAC, M- Mirror, B - Egress Blackhole,
b - Ingress Blackhole, v - MAC-Based VLAN, P - Private VLAN, T - VLAN translation,
D - drop packet, h - Hardware Aging, o - IEEE 802.1ah Backbone MAC,
S - Software Controlled Deletion, r - MSRP,
X - VXLAN, Z - OpenFlow, E - EVPN
Total: 16 Static: 8 Perm: 0 Dyn: 8 Dropped: 0 Locked: 0 Locked with Timeout: 0
FDB Aging time: 300
Leaf2.7 # show iparp
VR-Default 10.1.100.1 00:00:0b:cb:21:a4 7 NO tenant 10 66
VR-Default 10.1.100.2 00:00:0c:34:c1:ed 7 NO tenant 10 4
VR-Default 10.1.100.5 00:00:0c:14:88:4b 31 NO tenant 10 53
VR-Default 192.168.3.1 00:04:96:9c:2d:24 33 NO trunk2_3 4090 57
VR-Default 192.168.4.1 00:04:96:9b:b7:c9 33 NO trunk2_4 4089 49
VR-Default 20.1.100.1 00:00:04:d6:4d:6e 7 NO untagtenant 4088 66
VR-Default 20.1.100.2 00:00:04:d6:4d:6f 31 NO untagtenant 4088 4
VR-Default 20.1.100.5 00:00:00:1c:7e:5f 31 NO untagtenant 4088 53
VR-Default 20.1.100.6 00:00:00:47:ce:73 0 YES untagtenant 4088 VR-Default:5.5.5.5
VR-Default 192.168.5.0 00:04:96:a3:fb:b0 33 NO trunk1_2 4001 66
VR-Default 172.16.1.0 00:04:96:a3:fb:b0 33 NO isc 4000 66
Dynamic Entries : 10 Static Entries : 2
Pending Entries : 0
Timeout : 60 minutes ARP Sender-Mac Learning : Disabled
Reachable Time : 2700000 milliseconds (Auto)
ARP Global Settings
Max Entries : 12288
(Software Update Required) Leaf2.8 # show fdb
00:00:00:1c:7e:5f untagtenant(4088) 0000 d mi S 53
00:00:00:47:ce:73 untagtenant(4088) 0000 s m SXE VR-Default:5.5.5.5
00:00:04:d6:4d:6e untagtenant(4088) 0000 d mi S 66
00:00:04:d6:4d:6f untagtenant(4088) 0000 d mi 4
00:00:0b:cb:21:a4 tenant(0010) 0000 d mi S 66
00:00:0c:14:88:4b tenant(0010) 0000 d mi S 53
00:00:0c:34:c1:ed tenant(0010) 0000 d mi 4
00:04:96:9b:b7:c9 trunk2_4(4089) 0000 d mi 49
00:04:96:9c:2d:24 trunk2_3(4090) 0000 d mi 57
00:04:96:a3:fb:b0 tenant(0010) 0000 s m S 66
00:04:96:a3:fb:b0 untagtenant(4088) 0000 s m S 66
00:04:96:a3:fb:b0 trunk1_2(4001) 0000 s m S 66
00:04:96:a3:fb:b0 isc(4000) 0000 s m S 66
00:11:88:ff:04:74 untagtenant(4088) 0000 s m SXE VR-Default:5.5.5.5
FDB Aging time: 300
Leaf3.14 # show iparp
VR-Default 192.168.6.1 00:04:96:9c:2d:24 20 NO leaf3_trunk1 4094 51
VR-Default 192.168.7.1 00:04:96:9b:b7:c9 20 NO leaf3_trunk2 4093 50
VR-Default 10.1.100.1 00:00:0b:cb:21:a4 0 YES tenant 10 VR-Default:1.1.1.200
VR-Default 10.1.100.2 00:00:0c:34:c1:ed 0 YES tenant 10 VR-Default:1.1.1.200
VR-Default 10.1.100.5 00:00:0c:14:88:4b 0 YES tenant 10 VR-Default:1.1.1.200
VR-Default 10.1.100.6 00:00:00:47:ce:72 15 NO tenant 10 1
VR-Default 20.1.100.1 00:00:04:d6:4d:6e 0 YES untagtenant 4090 VR-Default:1.1.1.200
VR-Default 20.1.100.2 00:00:04:d6:4d:6f 0 YES untagtenant 4090 VR-Default:1.1.1.200
VR-Default 20.1.100.5 00:00:00:1c:7e:5f 0 YES untagtenant 4090 VR-Default:1.1.1.200
VR-Default 20.1.100.6 00:00:00:47:ce:73 20 NO untagtenant 4090 1
Dynamic Entries : 4 Static Entries : 6
Pending Entries : 0
ARP Global Settings
Max Entries : 12288
(Software Update Required) Leaf3.15 # show fdb
00:00:00:1c:7e:5f untagtenant(4090) 0000 s mi XE VR-Default:1.1.1.200
00:00:00:47:ce:72 tenant(0010) 0000 d mi 1
00:00:00:47:ce:73 untagtenant(4090) 0000 d mi 1
00:00:04:d6:4d:6e untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
00:00:04:d6:4d:6f untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
00:00:0b:cb:21:a4 tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:00:0c:14:88:4b tenant(0010) 0000 s mi XE VR-Default:1.1.1.200
00:00:0c:34:c1:ed tenant(0010) 0000 s mi XE VR-Default:1.1.1.200
00:04:96:9b:b7:c9 leaf3_trunk2(4093) 0000 d mi 50
00:04:96:9c:2d:24 leaf3_trunk1(4094) 0000 d mi 51
00:04:96:9d:42:32 tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:04:96:9d:42:32 untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
00:04:96:a3:fb:b0 tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:04:96:a3:fb:b0 untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
Total: 14 Static: 10 Perm: 0 Dyn: 4 Dropped: 0 Locked: 0 Locked with Timeout: 0
FDB Aging time: 300
