This section provides a sample TACACS+ client configuration for TACACS+ accounting that:
All other client configuration features use the default settings as described Configuring the TACACS+ Client for Authentication and Authorization or in the Switch Engine v33.1.1 Command Reference Guide .
configure tacacs-accounting primary server 10.201.31.238 client-ip 10.201.31.85 vr "VR-Default" configure tacacs-accounting primary shared-secret purple configure tacacs-accounting secondary server 10.201.31.235 client-ip 10.201.31.85 vr "VR-Default" config tacacs-accounting secondary shared-secret purple enable tacacs-accounting
IPv6 server can be configured using the following commands:
configure tacacs-accounting primary server 2111::220 client-ip 2111::85 vr "VR-Default"
configure tacacs-accounting secondary server 2111::210 client-ip 2111::85 vr "VR-Default"
configure tacacs-accounting secondary shared-secret purple
configure tacacs-accounting primary server 1111::220 client-ip 1111::170 vr vr-mgmt
To display the TACACS+ client accounting configuration, use the show tacacs or the show tacacs-accounting command. The following is sample output from the show tacacs command:
TACACS+: enabled
TACACS+ Authorization: enabled
TACACS+ Accounting : enabled
TACACS+ Server Connect Timeout sec: 3
Primary TACACS+ Server:
Server name :
IP address : 10.201.31.238
Server IP Port: 49
Client address: 10.201.31.85 (VR-Default)
Shared secret : purple
Secondary TACACS+ Server:
Server name :
IP address : 10.201.31.235
Server IP Port: 49
TACACS+ Acct Server Connect Timeout sec: 3
Primary TACACS+ Accounting Server:
Server name :
Server IP Port: 49
Secondary TACACS+ Accounting Server:
Server name :
Server IP Port: 49
