This section lists the new and corrected features supported in the 33.1.100 software:
The following additional SNMPv3 password and key policies have been added in this release to provide more security:
The following command can be used to enable or disable all the management access modes in the switch:
enable/disable switch access
The confidential information,sucg as all passwords, keys (symmetric and shared), and SNMP authentication details stored in the switch are not displayed in the configuration or CLI output with simple encoding, like BASE64. They are salted and encrypted by an entropy provider that is SP800-90B compliant.
When Korean CC mode is enabled on the switch from the CLI, FIPS mode is also enabled. FIPS mode remains enabled when switch is unconfigured after it was configured for Korean CC mode.
The following notes apply to an upgrade to openssl 3.0.1:
The following TLS ciphers are supported in 33.1.100:
This release has been updated so that a security profile can be configured for the switch for added security. When enabled, the profile remains enabled after upgrading the switch operating system and unconfiguring the switch.
show security profile
5420F-24S-4XE-SwitchEngine.10 # show security profile Security profile (current) : Off Security profile (configured) : Off
In this example output, the Korean CC profile has been configured and the switch has been rebooted:
5420F-24S-4XE-SwitchEngine.2 # show security profile Security profile (current) : Korean Common Criteria Security profile (configured) : Korean Common Criteria
The following command configures the Korean CC security profile:
configure security profile [korean-cc]
The following command can be used to unconfigure the security profile:
This command returns the switch to factory default settings.unconfigure switch erase [all | nvram]
With security profile set to Korea-CC, both http/https is set to disabled when enhanced security mode is run. Even if http and https is enabled using the CLI - WEBUI Chalet will not work in Korean-CC security mode.A new hardware self-test is run during system initialization. The self-test checks the status of the CPU, memory, flash memory, network interface, and power, and then creates a report with pass/fail results of the self-test. The report can be displayed in the CLI and summary results are included in the audit log.
The following command displays the hardware self-test results on a standalone switch:
show diagnostics boot-time
Example:
# show diagnostics boot-time Switch: 5520-48T-ACDC Time: Thu May 23 18:47:34 2024 Component Result Details ==================== ====== ================================================= CPU PASS Memory PASS Storage PASS Power FAIL PSU-1: Powered On, PSU-2: Power Failed Mgmt interface PASS Mgmt interface present, Link Up
There is an existing CLI command that performs a software self-test, consisting of software diagnostic checks, and then creates a summarized report on the results of the self-test. The report is displayed in the CLI command output and in the audit log. The same software will only execute during switch bootup in Korean CC mode.
The following command displays the software self-test results on a standalone switch:
show process
Example:
# show process Process Name Version Restart State Start Time Group ------------------------------------------------------------------------------- aaa 3.0.0.4 0 Ready Sat Dec 11 22:42:28 2021 Vital acl 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital bfd 1.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital bgp 4.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital brm 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Vital cfgmgr 3.0.0.21 0 Ready Sat Dec 11 22:42:28 2021 Vital cli 3.0.0.22 0 Ready Sat Dec 11 22:42:28 2021 Vital devmgr 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital dirser 3.0.0.2 0 Ready Sat Dec 11 22:42:27 2021 Vital dosprotect 3.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital dot1ag 1.0.0.1 0 Ready Sat Dec 11 22:42:29 2021 Vital eaps 3.0.0.8 0 Ready Sat Dec 11 22:42:28 2021 Vital edp 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital elrp 3.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital elsm 3.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital ems 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital epm 3.0.0.4 0 Ready Sat Dec 11 22:42:26 2021 Vital erps 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Vital esrp 3.0.0.4 0 Ready Sat Dec 11 22:42:28 2021 Vital ethoam 1.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital etmon 1.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital exacl 3.0.0.2 0 Ready Sat Dec 11 22:42:27 2021 Kernel exdhcpsnoop 1.0.0.1 0 Ready Sat Dec 11 22:42:27 2021 Kernel exdos 3.0.0.2 0 Ready Sat Dec 11 22:42:26 2021 Kernel exfib 1.0.0.2 0 Ready Sat Dec 11 22:42:27 2021 Kernel exfipSnoop 1.0.0.0 0 Ready Sat Dec 11 22:42:27 2021 Kernel exosmc 3.0.0.2 0 Ready Sat Dec 11 22:42:27 2021 Kernel exosq 3.0.0.2 0 Ready Sat Dec 11 22:42:26 2021 Kernel exsflow 1.0.0.2 0 Ready Sat Dec 11 22:42:27 2021 Kernel exsnoop 3.0.0.2 0 Ready Sat Dec 11 22:42:27 2021 Kernel exsshd 6.5.1.69 0 Ready Sat Dec 11 22:42:29 2021 Other exvlan 3.0.0.2 0 Ready Sat Dec 11 22:42:27 2021 Kernel fcoe 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Vital fdb 7.1.0.0 0 Ready Sat Dec 11 22:42:28 2021 Vital gptp 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Vital hal 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital hclag 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Vital idMgr 1.0.1.1 0 Ready Sat Dec 11 22:42:29 2021 Vital ipSecurity 1.0.0.1 0 Ready Sat Dec 11 22:42:29 2021 Vital ipfix 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital isis 1.0.0.2 0 Ready Sat Dec 11 22:42:29 2021 Vital ismb 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Vital lacp 3.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital lldp 1.2.0.0 0 Ready Sat Dec 11 22:42:28 2021 Vital mcmgr 4.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital mpls Not Started 0 No license Not Started Vital mrp 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Vital msdp 1.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital netLogin 2.1.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital netTools 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital nettx 3.0.0.2 0 Ready Sat Dec 11 22:42:26 2021 Kernel nodealias 1.0.0.1 0 Ready Sat Dec 11 22:42:29 2021 Vital nodealias_snoop 1.0.0.1 0 Ready Sat Dec 11 22:42:27 2021 Kernel nodemgr 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital ntp 4.2.6.3 0 Ready Sat Dec 11 22:42:29 2021 Vital ospf 3.0.0.3 0 Ready Sat Dec 11 22:42:28 2021 Vital ospfv3 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital otm 1.0.0.1 0 Ready Sat Dec 11 22:42:29 2021 Vital pim 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital polMgr 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital policy 1.0.0.1 0 Ready Sat Dec 11 22:42:29 2021 Vital pwmib 1.0.0.0 0 Ready Sat Dec 11 22:42:28 2021 Vital rip 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital ripng 3.0.0.1 0 Ready Sat Dec 11 22:42:28 2021 Vital rtmgr 4.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital snmpMaster 4.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital snmpSubagent 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital stp 3.0.4.4 0 Ready Sat Dec 11 22:42:28 2021 Vital techSupport 1.0.0.0 0 Ready Sat Dec 11 22:42:28 2021 Vital telnetd 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Other tftpd 3.0.0.2 0 Ready Sat Dec 11 22:42:28 2021 Vital thttpd 1.0.0.0 0 Ready Sat Dec 11 22:42:29 2021 Other twamp 1.0.0.1 0 Ready Sat Dec 11 22:42:29 2021 Vital upm 1.0.0.1 0 Ready Sat Dec 11 22:42:29 2021 Vital vlan 4.1.0.3 0 Ready Sat Dec 11 22:42:28 2021 Vital vmt 1.0.1.1 0 Ready Sat Dec 11 22:42:29 2021 Vital vrrp 3.0.0.5 0 Ready Sat Dec 11 22:42:28 2021 Vital vsm 1.0.0.2 0 Ready Sat Dec 11 22:42:29 2021 Vital xmlc 1.0.1.0 0 Ready Sat Dec 11 22:42:29 2021 Vital xmld 1.0.0.0 0 Ready Sat Dec 11 22:42:28 2021 Vital
This version makes the mask field of IPv4 and IPv6 address in ACL an optional field. If the mask is not added to the IPv4 address, it is internally assumed to be a 32-bit mask. For an IPv6 address, it is assumed to be a 128-bit mask.
