mint
      Displays MiNT protocol related
         statistics and configuration
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
      Syntax
         show mint [config|dis|id|info|known-adopters|links|lsp|lsp-db|mlcp|neighbors|route|
 stats|tunnel-controller|tunneled-vlans]
         show mint [config|id|info|known-adopters|route|stats|tunneled-vlans]
{on <DEVICE-NAME>}
         show mint [dis|links|neighbors|tunnel-controller] {details} {(on <DEVICE-NAME>)}
         show mint lsp
         show mint lsp-db {details <MINT-ADDRESS>} {(on <DEVICE-NAME>)}
         show mint mlcp {history} {(on <DEVICE-NAME>)}
      Parameters
         show mint [config|id|info|known-adopters|route|stats|tunneled-vlans] {on <DEVICE-NAME>}
                     | mint |
                     Displays MiNT protocol information based on the parameters
                        passed |
                     | config |
                     Displays MiNT configuration |
                     | id |
                     Displays local MiNT ID |
                     | info |
                     Displays MiNT status |
                     | known-adopters |
                     Displays known, possible, or reachable adopters |
                     | route |
                     Displays MiNT route table details |
                     | stats |
                     Displays MiNT related statistics |
                     | tunneled-vlans |
                     Displays MiNT tunneled VLAN details |
                     | on <DEVICE-NAME> |
                     The following keywords are common to all of the above parameters:
                           - on <DEVICE-NAME>
                              – Optional. Displays MiNT protocol details on a specified device
                                 - <DEVICE-NAME> – Specify the name of the AP, wireless
                                    controller, or service platform.
                     | mint |
                        passed |
                     | dis |
                     Displays MiNT network Designated Intermediate Systems (DISes) and
                           Ethernet Virtualization Interconnects (EVISes) |
                     | links |
                     Displays MiNT networking link details |
                     | neighbors |
                     Displays adjacent MiNT peer details |
                     | tunnel-controller |
                     Displays details of MiNT VLAN network tunnel wireless controllers for
                        extended VLAN load balancing |
                     | details {(on <DEVICE-NAME>)} |
                     The following keywords are common to the ‘dis', ‘links', ‘neighbors',
                        and ‘tunnel-controller' parameters:
                           - details – Optional.
                              Displays detailed MiNT information
                                 - on
                                    <DEVICE-NAME> – Optional. This is a recursive parameter,
                                    which displays MiNT information on a specified device
                                          wireless controller, or service platform.
         show mint lsp
                     | mint |
                        passed |
                     | lsp |
                     Displays this router's MiNT Label Switched Paths (LSPs) |
                     | mint |
                        passed |
                     | lsp-db |
                     Displays MiNT LSP database entries |
                     | details <MINT_ADDRESS> |
                     Optional. Displays detailed MiNT LSP database entries
                           - <MINT_ADDRESS> –
                              Specify the MiNT address in the AA.BB.CC.DD format.
                     | on <DEVICE-NAME> |
                     The following keyword is recursive and common to the ‘details'
                           parameter:
                           - on <DEVICE-NAME>
                              – Optional. Displays MiNT LSP database entries on a specified
                                 device
                     | mint |
                     Displays MiNT protocol information based on the parameters passed This
                           command displays the ‘hello-interval‘ and ‘hold-time‘ default values for
                           both IP and VLAN links.
                     | mlcp |
                     Displays MiNT Link Creation Protocol (MLCP) status |
                     | history |
                     Optional. Displays MLCP client history |
                     | on <DEVICE-NAME> |
                     The following keyword is recursive and common to the ‘history'
                           parameter:
                           - on <DEVICE-NAME>
                              – Optional. Displays MLCP client history on a specified device
         NOC-NX9500#show mint stats
2 Level-1 neighbors
Level-1 LSP DB size 5 LSPs (1 KB)
Last Level-1 SPFs took 0.000s
Level-1 SPF (re)calculated 6 times.
5 Level-1 paths.
0 Level-2 neighbors
Level-2 LSP DB size 0 LSPs (0 KB)
Last Level-2 SPFs took 0.000s
Level-2 SPF (re)calculated 0 times.
0 Level-2 paths.
NOC-NX9500#
         NOC-NX9500#show mint lsp
id 19.6C.88.09, level 1, 2 adjacencies, 0 extended-vlans
seqnum 1519955, expires in 22 minutes, republish in 774 seconds
90 bytes, can-adopt: True, adopted-by: 00.00.00.00, dis-priority 5, Level-2-gateway: False
hostname "NOC-NX9500"
rf-domain "default", priority vector: 0xe0dc0000
adjacent to 70.38.06.49, cost 100
adjacent to 19.6D.B5.D4, cost 100
NOC-NX9500#
         NOC-NX9500#show mint lsp-db
5 LSPs in LSP-db of 19.6C.88.09:
LSP 19.6C.88.09 at level 1, hostname "NOC-NX9500", 2 adjacencies, seqnum 1519955
LSP 19.6D.B5.D4 at level 1, hostname "SITE2-VLAN192", 2 adjacencies, seqnum 1972642
LSP 19.74.B4.5C at level 1, hostname "ap8132-74B45C", 1 adjacencies, seqnum 1742227
LSP 4D.83.30.A4 at level 1, hostname "ap7522-8330A4", 1 adjacencies, seqnum 519924
LSP 70.38.06.49 at level 1, hostname "SITE1-VLAN20", 2 adjacencies, seqnum 1391030
NOC-NX9500#
         NOC-NX9500#show mint route
Destination : Next-Hop(s)
19.6D.B5.D4 : 19.6D.B5.D4 via ip-192.168.13.2:24576
19.74.B4.5C : 19.6D.B5.D4 via ip-192.168.13.2:24576
19.6C.88.09 : 19.6C.88.09 via self
70.38.06.49 : 70.38.06.49 via ip-20.168.10.2:24576
4D.83.30.A4 : 70.38.06.49 via ip-20.168.10.2:24576
NOC-NX9500#
         NOC-NX9500#show mint config
Base priority 5
DIS priority 5
Control priority 220
UDP/IP Mint encapsulation port 24576
Global Mint MTU 1500
NOC-NX9500#
         NOC-NX9500#show mint mlcp
MLCP VLAN state: MLCP_INIT
MLCP VLAN Hello Interval: 4s(default), Adjacency hold time: 13s(default)
  Potential VLAN links:  None
  All VLANs were scanned 1 times
MLCP IP: ENABLED
MLCP IPv6: ENABLED
MLCP IP/IPv6 state: MLCP_INIT
MLCP IP Hello Interval: 15s(default), Adjacency hold time: 46s(default)
  Potential L3 Links:
   None
NOC-NX9500#
