Defines the L2TPV3 settings for tunneling layer 2 payloads using VPNs
L2TPv3 is an IETF standard that defines the control and encapsulation protocol settings for tunneling layer 2 frames in an IP network (and access point profile) between two IP nodes. Use L2TPv3 to create tunnels for transporting layer 2 frames. L2TPv3 enables WiNG supported controllers and access points to create tunnels for transporting Ethernet frames to and from bridge VLANs and physical ports. L2TPv3 tunnels can be defined between WiNG devices and other vendor devices supporting the L2TPv3 protocol.
l2tpv3 [hostname <HOSTNAME>|inter-tunnel-bridging|manual-session| router-id [<1-4294967295>|<IP>]|tunnel|udp-listen-port <1024-65535>]
| l2tpv3 | Configures the L2TPv3 protocol settings for a profile |
| hostname <HOSTNAME> | Configures the host name sent in the L2TPv3
signaling messages. Tunnel establishment involves
exchanging 3 message types (SCCRQ, SCCRP, and SCCN) with
the peer. Tunnel IDs and capabilities are exchanged
during the tunnel establishment with the host.
| inter-tunnel-bridging | Enables inter tunnel bridging of packets. This feature is disabled by default. |
| manual-session | Creates/modifies L2TPv3 manual sessions For more information, see l2tpv3-manual-session-commands. |
| router-id [<1-4294967295>| <IP>] | Configures the router ID (either the
numeric IP address or the integer) sent in the L2TPv3
signaling messages. These signaling (AVP) messages help
to identify tunneled peers.
| tunnel | Creates/modifies an L2TPv3 tunnel For more information, see l2tpv3-tunnel-commands. |
| udp-listen-port <1024-65535> | Configures the UDP port used to listen for
incoming traffic
l2tpv3 logging ip-address [<IP>|any] hostname [<HOSTNAME>|any] router-id [<IP>|<WORD>|any]
| l2tpv3 | Configures L2TPv3 protocol settings for a profile |
| logging | Enables L2TPv3 tunnel event logging and debugging. When enabled, all events relating to Ethernet frames to and from bridge VLANs and physical ports on a specified IP address, host or router ID are logged. This option is disabled by default. |
| ip-address [<IP>|any] | Configures the L2TPv3 peer tunnel IP
address for which event logging is enabled. The options
are:
| hostname [<HOSTNAME>| any] | Configures the L2TPv3 peer tunnel hostname
for which event logging is enabled. The options are:
| router-id [<IP>|<WORD>|any] | Configures the L2TPv3 tunnel router ID for
nx9500-6C8809(config-profile-TestNX5500)#l2tpv3 hostname l2tpv3Host1 nx9500-6C8809(config-profile-TestNX5500)#l2tpv3 inter-tunnel-bridging nx9500-6C8809(config-profile-TestNX5500)#show context profile nx5500 TestNX5500 bridge vlan 1 bridging-mode isolated-tunnel ip igmp snooping ip igmp snooping querier ................................................. l2tpv3 hostname l2tpv3Host1 l2tpv3 inter-tunnel-bridging nx9500-6C8809(config-profile-TestNX5500)#
| no | Negates a L2TPv3 tunnel settings on this profile |
