spanning-tree
      Supported in the
            following platforms:
            - Service Platforms —
               NX5500, NX7500, NX9500, NX9600, VX9000
      spanning-tree [bpdufilter|bpduguard|force-version|guard|link-type|mst|port-cisco-interoperability|portfast]
      spanning-tree [bpdufilter|bpduguard] [default|disable|enable]
      spanning-tree [force-version <0-3>|guard root|portfast|port-cisco-interoperability [disable|enable]]
      spanning-tree link-type [point-to-point|shared]
      spanning-tree mst <0-15> [cost <1-200000000>|port-priority <0-240>]]
      Parameters
                        bpduguard] |
                     Configures the following BPDU related parameters for this port channel:
                           - bpdufilter – Configures the BPDU filtering options. The options are:
                                 - default – When selected, makes the bridge BPDU filter value to take effect. This is the default setting.
                                 - disable – Disables BPDU filtering
                                 - enable – Enables BPDU filtering. Enabling the BPDU filter feature ensures this port channel does not transmit or receive any BPDUs.
                           - bpduguard – Configures the BPDU guard options. The options are
                                 - default – When selected, makes the bridge BPDU guard value to take effect. This is the default setting.
                                 - disable – Disables guarding this port from receiving BPDUs
                                 - enable – Enables BPDU guarding. Enabling the BPDU guard feature means this port will shutdown on receiving a BPDU. Thus, no BPDUs are processed.
                         Execute the portfast command to ensure that fast transitions is enabled on this port channel before configuring BPDU filtering and guarding.
                        guard root| portfast| port-cisco-interoperability
                        [disable|enable] |
                     Configures the following MSTP related
                           - force-version <0-3> – Sets the protocol
                              version to either STP(0), Not Supported(1),
                              RSTP(2) or MSTP(3). MSTP is the default
                              setting
                           - guard
                              root – Enforces root bridge placement. Setting the
                              guard to Root ensures the port is a designated
                              port. Typically, each guard root port is a
                              designated port, unless two or more ports (within
                              the root bridge) are connected together.
                         If the bridge receives superior (BPDUs) on a guard
                        root-enabled port, the guard root moves the port to a
                        root-inconsistent STP state. This state is equivalent to
                        a listening state. No data is forwarded across the port.
                        Thus, the guard root enforces the root bridge
                           position.
                           - portfast – Enables fast transitions on this port
                              channel. When enabled, BPDU filtering and guarding
                              can be enforced on this port. Enable the portfast
                              option and then use the ‘bpdufilter‘ and
                              bpduguard‘ options to configure BPDU filtering and
                              guarding parameters. This option is disabled by
                              default.
                           - port-cisco-interoperability [disable|enable] –
                              Enables or disables interoperability with Cisco's
                              version of MSTP, which is incompatible with
                              standard MSTP. This option is disabled by
                              default.
                        shared] |
                     Configures the link type applicable on this port channel. The options are:
                           - point-to-point – Configures a point-to-point link, which indicates the port should be treated as connected to a point-to-point link. Note, a port connected to the wireless device is a point-to-point link. This is the default setting.
                           - shared – Configures a shared link, which indicates this port should be treated as having a shared connection. Note, A port connected to a hub is on a shared link.
                        <1-200000000>| port-priority
                        <0-240>] |
                     Configures the following MST parameters on
                        this port:
                           - mst
                              <0-15> – Select the MST instance from 0 -
                                 15.
                                 - cost <1-200000000> – Configures the
                                    port cost from 1 - 200000000. The default
                                    path cost depends on the user defined port
                                    speed.The cost helps determine the role of
                                    the port channel in the MSTP network. The
                                    designated cost is the cost for a packet to
                                    travel from this port to the root in the
                                    MSTP configuration. The slower the media,
                                    higher the cost.
                           - port-priority <0-240> – Configures the port
                              priority from 0 - 240. The lower the priority,
                              greater is the likelihood of the port becoming a
                              designated port.
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#spanning-tree portfast
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#spanning-tree bpdufilter enable
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#spanning-tree bpduguard enable
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#spanning-tree force-version 3
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#spanning-tree mst 1 cost 20000
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#spanning-tree mst 1 port-priority 1
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#show context
 interface port-channel1
  description "This port-channel is for enabling dynamic LACP."
  duplex full
  ipv6 nd trust
  ipv6 nd header-mismatch-validation
  ip arp trust
  port-channel load-balance src-dst-mac
      Related Commands
                     | no |
                     Removes or reverts to default the spanning-tree related parameters configured on this port channel interface |
