Enables forwarding of bridge-vlan information (such as, name and vlan) to the ExtremeGuest (EGuest) server. The EGuest server updates its WLAN information collection with the received wired-network information.
Ensure that the bridge-vlan interface has a name that uniquely identifies it from other bridge-vlan interfaces with similar configurations. For more information, see name.Captive-portal Web pages for wired clients are hosted on the gateway controller‘s bridge-vlan interface. By updating the EGuest server with bridge-vlan information, you enable the EGuest server to apply of captive-portal‘s Splash templates to the bridge-vlan interface.
This command also configures the external guest registration and validation server details. If using an external server to perform wired client registration, authentication and accounting, use this command to configure the external server‘s IP address/hostname. When configured, the gateway controller forwards guest registration requests to the specified registration server. In case of EGuest deployment, this external resource should point to the EGuest server.
registration [device|device-OTP|external|user]
registration [device|device-OTP|user] group-name <RAD-GROUP-NAME> {expiry-time <1-43800>}
      registration external follow-aaa send-mode [http|https|udp]
| registration |
                         Enables wired guest-user registration and validation. This option is disabled by default. Use to configure registration and validation parameters for wired captive-portal clients. Specify the client registration mode used. If using an external resource as authenticating server, use this command to point to the external resource.  |
| [device|device-OTP| user] | Configures the
                        mode used to register wired clients on this bridge-vlan interface. The
                        options are: device, user, and device-OTP.
 If using any one of the above modes of registration, specify the RADIUS group to which the registered device or user is to be assigned post authentication.  |
| group-name <RAD-GROUP-NAME> | Configures the
                        RADIUS group name in which registered users are placed. When left blank,
                        users are not associated with a RADIUS group.
| expiry-time <1-43800> | Optional.
                        Configures the duration in hours, or which registered MAC addresses are
                        retained. Once this duration is over, registered MAC addresses expire and
                        need to be re-entered.
| registration |
| external | Specifies that the wired client registration is handled by an external resource. Registration requests are forwarded to the external registration server by the captive-portal gateway controller. |
| follow-aaa | Uses an AAA
                        policy to point to the guest registration, authentication, and accounting
                        server. When used, guest registration is handled by the RADIUS server
                        specified in the AAA policy. This is the AAA policy used in the
                        captive-portal applied on the bridge-vlan interface. In case of EGuest deployment, in the AAA policy, the RADIUS authentication and accounting server configuration should point to the EGuest server. The use of ‘follow-aaa‘ option is recommended in EGuest replica-set deployments. For more information on enabling the EGuest server, see eguest-server (VX9000 only) (profile config mode).  |
| send-mode [https|https|udp] | Specifies the
                        protocol used to forward registration requests to the external AAA policy
                        server. The options are:
nx9500-6C8809(config-profile testNX9500-bridge-vlan-20)#registration device group-name test expiry-time 200
nx9500-6C8809(config-profile testNX9500-bridge-vlan-20)#registration external follow-aaa send-mode https
nx9500-6C8809(config-profile testNX9500-bridge-vlan-20)#show context bridge vlan 20 registration device group-name test expiry-time 200 registration external follow-aaa send-mode https ip igmp snooping ip igmp snooping querier ipv6 mld snooping ipv6 mld snooping querier nx9500-6C8809(config-profile testNX9500-bridge-vlan-20)#
| no | Disables self-registration of captive-portal users on this bridge-vlan interface. |
