For radio 2, use theantenna-id command to specify the antenna type used in
                                ports 1, 2, 3, and 4.
For radio 1, use theantenna-id
                                command to specify the antenna type used in antenna ports 5
                                and 6.
For radio 3, use theantenna-id command to specify the antenna type used in
                                antenna ports 7 and 8.antenna-id external [group-1|group-2|group-3] <ANTENNA-TYPE>
| antenna-id | Selects the antenna group to use. |
| external | States the antenna is external |
| group-1 | Configures the antenna type used in the group-1 antenna ports (1,
                                2, 3, and 4).  Note: For AP460e, radio 2 and antennas 1,
                                        2, 3, and 4 are 5 GHz band-locked. For radio 2, use the
                                    type used in antenna ports 1, 2, 3, and 4.  |
| group-2 | Configures the antenna type used in the group-2 antenna ports (5
                                and 6).  Note: For AP460e, radio 1 and antennas 5
                                        and 6 are 2.4 GHz band-locked. For radio 1, use the
                                    type used in antenna ports 5 and 6. |
| group-3 | Configures the antenna type used in the group-3 antenna ports (7
                                and 8).  Note: For AP460e, radio 3 and antennas 7
                                        and 8 are dual-band, concurrent, sensor only. For radio
                                    3, use the
                                    antenna type used in antenna ports 7 and 8. |
| antenna-type | After selecting the
                                antenna group, configure the antenna-type used: The antenna types supported for group-1, group-2 and group-3 antenna ports are: ai-dq04360s, ml-2452-apa2-01, ml-2452-apa2-02, ml-2452-hpa5-036, ml-2452-hpag4a6-01, ml-2452-hpag5a8-01, ml-2452-pna5-01r, ml-2452-pta4m4-036, ml-2452-sec6m4-036, ws-ai-de07025, ws-ai-de10055, ws-ai-dq05120, and ws-ao-dq04360n.  |
nx9500-6C8809(config-profile-testAP460e)#antenna-id external ?
  group-1  Configure the antenna id on antenna group 1 (2.4/5GHz dual band
           antenna)
  group-2  Configure the antenna id on antenna group 2 (5GHz single band
           antenna or 2.4GHz single band antenna)
  group-3  Configure the antenna id on antenna group 3 (2.4/5GHz dual band
           antenna on radio 3)
            nx9500-6C8809(config-profile-testap460e)#antenna-id external group-1 ?
  ai-dq04360s         AI-DQ04360S Dual Band, Four Input Omni, 36 Inch Cable
  default             Internal antenna for internal SKU, auto select antenna
                      for external SKU
  ml-2452-apa2-01     ML-2452-APA2-01 3dBi/4.85dBi, dual band, black
  ml-2452-apa2-02     ML-2452-APA2-02 3dBi/4.85dBi, dual band, white
  ml-2452-hpa5-036    ML-2452-HPA5-036 3dBi/5dBi, dual band, outdoor, white
  ml-2452-hpag4a6-01  ML-2452-HPAG4A6-01 4dBi/7.3dBi, N-type male, dual band,
                      outdoor, white
  ml-2452-hpag5a8-01  ML-2452-HPAG5A8-01
  ml-2452-pna5-01r    ML-2452-PNA5-01R 2.4/5 GHz, Outdoor, Panel, 5 dBi, Beam
                      Width: E-Plane: 65 degrees, H-Plane: 120 degrees
  ml-2452-pna7-01r    ML-2452-PNA7-01R 8/12dBi 68deg Panel
  ml-2452-pta4m4-036  ML-2452-PTA4M4-036 4dBi/5 dBi, 4 port, dual band
  ml-2452-sec6m4-036  ML-2452-SEC6M4-036 DUAL POLARIZED DUAL BAND WIDE BEAM
                      DIRECTIONAL ANTENNA WITH 36 INCH CABLE
  ws-ai-dq05120       WS-AI-DQ05120 DUAL POLARIZED DUAL BAND WIDE BEAM
            nx9500-6C8809(config-profile-testap460)#antenna-id external group-1 ai-dq04360s
nx9500-6C8809(config-profile-testap460e)#show context include-factory | include antenna-id antenna-id external group-1 ai-dq04360s antenna-id external group-2 default antenna-id external group-3 default antenna-id internal internal-560h-30 nx9500-6C8809(config-profile-testap460e)#
| no | Removes the antenna-id configuration on the selected AP460e profile and device. |
