Enables forwarding of HTTP request related data to the HTTP analytics engine
Wireless clients (MUs) connect to APs and route their HTTP requests through the APs. These APs extract and forward HTTP request packets, through MiNT, to the NX series controller. The NX series controller uses a new analytic daemon to cache, format, and forward information to the analytics engine. Currently the analytics daemon is supported only on the NX series service platform. Therefore, it is essential that all APs should use an NX series service platform as controller.
In a hierarchically organized network, HTTP analytics data forwarding is a simple and transparent process. The site controllers receive the HTTP data from adopted APs adopted. This data is compressed and forwarded to the NOC (Network Operations Center) controller. There is no need for a separate configuration to enable this feature.
Use this command to configure the mode and interval at which data is sent to the controller and the external analytics engine. This command also configures the external engine‘s details, such as URL, credentials, etc.
The Analytics module helps gather data about customer behavior such as web sites visited, search terms used, mobile device types, number of new users vs. repeat users. This data provides a better understanding of pricing strategies and promotions being run by competitors.http-analyze [compress|external-server|update-interval <1-3600>]
http-analyze [compress|update-interval <1-3600>
http-analyze external-server [password <WORD>|proxy <URL>|update-interval <1-3600>|url <URL>|username <WORD>|validate-server-certificate]
http-analyze [compress|update-interval <1-3600>]
| http-analyze | Configures HTTP analysis related parameters |
| compress | Compresses update files before forwarding to the controller. This option is disabled by default. |
| update-interval <1-3600> | Configures the
                        interval, in seconds, at which buffered packets are pushed to the
                           controller
http-analyze external-server [password <WORD>|proxy <URL>|update-interval| url|username|validate-server-certificate]
| http-analyze external-server | Configures the external HTTP analytics engine‘s parameters |
| password <WORD> | Configures the
                        external analytics engine‘s password
| proxy <URL> | Configures the
                        proxy server‘s URL
| update-interval <1-36000> | Configures the
                        interval, in seconds, at which buffered packets are pushed to the external
                        analytics engine
| url <URl> | Configures the
                        external analytics engine‘s IP address or URL
| username <WORD> | Configures the
                        user name needed to access the external analytics engine
| validate-server-certificate | Validates the external analytics engine‘s certificate, if it is using HTTPS as the mode of access |
nx9500-6C8809(config-profile-default-nx5500)#http-analyze compress nx9500-6C8809(config-profile-default-nx5500)#http-analyze update-interval 200 nx9500-6C8809(config-profile-default-nx5500)#show context profile nx5500 default-nx5500 bridge vlan 1 ..................................................................... qos trust 802.1p interface pppoe1 use firewall-policy default http-analyze update-interval 200 http-analyze compress service pm sys-restart router ospf nx9500-6C8809(config-profile-default-nx5500)# nx9500-6C8809(config-profile-test-nx5500)#http-analyze external-server username anonymous nx9500-6C8809(config-profile-test-nx5500)#http-analyze external-server password anonymous nx9500-6C8809(config-profile-test-nx5500)#http-analyze external-server validate-server-certificate nx9500-6C8809(config-profile-test-nx5500)#http-analyze external-server update-interval 100 nx9500-6C8809(config-profile-test-nx5500)#http-analyze external-server url https://192.168.13.10 nx9500-6C8809(config-profile-test-nx5500)#show context profile nx5500 test-nx5500 no autoinstall configuration no autoinstall firmware ...................................................... interface ge5 interface ge6 interface pppoe1 use firewall-policy default export startup-log max-retries 10 retry-interval 30 url ftp://anonymous:anonymous@192.168.13.10/log/startup.log http-analyze external-server url https://192.168.13.10 http-analyze external-server username anonymous http-analyze external-server password anonymous http-analyze external-server update-interval 100 enforce-version adoption major enforce-version cluster full --More-- nx9500-6C8809(config-profile-test-nx5500)# nx9500-6C8809(config-profile-test-nx5500)#http-analyze external-server proxy http://mot:sym@wwwgate0.mot.com:1080 nx9500-6C8809(config-profile-test-nx5500)#show context profile nx5500 test-nx5500 no autoinstall configuration no autoinstall firmware crypto ikev1 policy ikev1-default isakmp-proposal default encryption aes-256 group 2 hash sha crypto ikev2 policy ikev2-default ............................................................... http-analyze external-server url https://192.168.13.10 http-analyze external-server username anonymous http-analyze external-server password anonymous http-analyze external-server update-interval 100 http-analyze external-server proxy http://mot:sym@wwwgate0.mot.com:1080 enforce-version adoption major enforce-version cluster full service pm sys-restart router ospf router bgp dot1x system-auth-control dot1x use aaa-policy OnBoarding nx9500-6C8809(config-profile-test-nx5500)#
| no | Disables HTTP analyze settings |
