crypto-remote-vpn-client commands
Specifies the IPSec Transform set to use with this remote VPN client. A transform set is a combination of security protocols, algorithms, and other settings applied to IPSec protected client traffic.
transform-set <IPSEC-XFORM-TAG> {<IPSEC-XFORM-TAG>}
| transform-set <IPSEC-XFORM-TAG> <IPSEC-XFORM-TAG> | Associates an
                        IPSec Transform (should be existing and configured) set with this remote VPN
                        client. You can optionally associate more than one transform set with this
                        remote VPN client configuration. List the transform set tags separated by a
                           space. Note: To
                           configure a transform-set, use the
                            crypto > ipsec > transform-setcommand in the profile or device configuration mode. |
nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#transform-set TransformSet1 nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#show context crypto remote-vpn-client peer 1 ikev2 ikev2Peer1 transform-set TransformSet1 nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#
