Enables HTML5-based NOVA UI. The following rules apply:
nova
no nova
None
The following example shows the current settings for the management policy named test-cw. In this example, nova is enabled, which is the default setting.
vx9000-3C6F18(config-management-policy-test-cw)#?
Management Mode commands:
aaa-login Set authentication for logins
allowed-locations Add allowed locations
banner Define a login banner
flash-ui Enable FLASH UI
ftp Enable FTP server
http Hyper Text Terminal Protocol (HTTP)
https Secure HTTP
idle-session-timeout Configure idle timeout for a configuration session
(GUI or CLI)
ipv6 IPv6 management access restriction
no Negate a command or set its defaults
nova Enable NOVA UI
passwd-retry Lockout user if too many consecutive login failures
privilege-mode-password Set the password for entering CLI privilege mode
rest-server Enable rest server for device on-boarding
functionality
restrict-access Restrict management access to the device
snmp-server SNMP
ssh Enable ssh
t5 T5 configuration
telnet Enable telnet
user Add a user account
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
In the following example, nova is first disabled using the no command, then it is re-enabled.
vx9000-3C6F18(config-management-policy-test-cw)#no nova vx9000-3C6F18(config-management-policy-test-cw)#show context management-policy test-cw no telnet no http server no nova no flash-ui https server rest-server ssh ssh enable-weak-mac-algo 1 vx9000-3C6F18(config-management-policy-test-cw)#nova vx9000-3C6F18(config-management-policy-test-cw)#show context management-policy test-cw no telnet no http server nova no flash-ui https server rest-server ssh ssh enable-weak-mac-algo 1 vx9000-3C6F18(config-management-policy-test-cw)#
In the following example, nova and https server are enabled. In this case, NOVA UI is reachable on port 443.
In the following example, nova and http server are enabled. In this case, NOVA UI is reachable on port 80.
vx9000-3C6F18(config-management-policy-test-cw)#no nova vx9000-3C6F18(config-management-policy-test-cw)#http server vx9000-3C6F18(config-management-policy-test-cw)#no https server vx9000-3C6F18(config-management-policy-test-cw)#nova vx9000-3C6F18(config-management-policy-test-cw)#show context management-policy test-cw no telnet http server nova no flash-ui no https server rest-server ssh ssh enable-weak-mac-algo 1 vx9000-3C6F18(config-management-policy-test-cw)#
| no | Disables NOVA UI access on the device |
