database-policy global config
    Creates a
      database-policy and enters its configuration mode. After creating the
      database-policy, use it on the database host. This enables the database.
      If deploying a database replica-set, use this command to define the
      replica set configurations. To enforce database authentication, enable
        authentication on the database-policy, and configure the username and
        password required to access the database. Note, this command is part of
        a set of configurations that are required to enable authentication. For
        more information on the entire set of configurations, see Example: Enabling Database Authentication.
    Supported in the
        following platforms:
        - Service Platforms —
          NX9500, NX9600, VX9000
    Syntax
      database-policy <DATABASE-POLICY-NAME>
    Parameters
              | database-policy <DATABASE-POLICY-NAME> |
              Specify the database policy name. If the policy with the specified name does
                not exist, it is created. |
nx9500-6C8809(config)#database-policy test
nx9500-6C8809(config-database-policy-test)#?
Database Policy Mode commands:
  authentication  Database authentication
  no              Negate a command or set its defaults
  replica-set     Replica Set
  shutdown        Disable database server
  clrscr          Clears the display screen
  commit          Commit all changes made in this session
  do              Run commands from Exec mode
  end             End current mode and change to EXEC mode
  exit            End current mode and down to previous mode
  help            Description of the interactive help system
  revert          Revert changes
  service         Service Commands
  show            Show running system information
  write           Write running configuration to memory or terminal
    Related
        Commands
              | no |
              Removes an existing database-policy |
              | database-client-policy global-config |
              Documents database-client policy configuration commands.
                The database-client-policy configures the IP address or hostname
                of the database host, and is used on the EGuest server‘s device
                context.  |
              | use (profile/device-config-mode-commands) |
              Uses a database-client-policy in the VX9000's device or
                profile context |
              | database |
              Drops or repairs a database. Also provides database keyfile
                management capabilities. If enforcing authenticated access to
                the database, use this command to generate, export, import, and
                zerzoise the keyfile. |
