wips-policy
      Configures a WIPS policy and enters its configuration
         mode
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
      Syntax
         wips-policy <WIPS-POLICY-NAME>
      Parameters
                     | <WIPS-POLICY-NAME> |
                     Specify the WIPS policy name. If a policy with the specified name does
                        not exist, it is created. |
         nx9500-6C8809(config)#wips-policy test
nx9500-6C8809(config-wips-policy-test)#?
Wips Policy Mode commands:
  ap-detection               Rogue AP detection
  enable                     Enable this wips policy
  event                      Configure an event
  history-throttle-duration  Configure the duration for which event duplicates
                             are not stored in history
  interference-event         Specify events which will contribute to smart-rf
                             wifi interference calculations
  no                         Negate a command or set its defaults
  signature                  Signature to configure
  use                        Set setting to use
  clrscr                     Clears the display screen
  commit                     Commit all changes made in this session
  do                         Run commands from Exec mode
  end                        End current mode and change to EXEC mode
  exit                       End current mode and down to previous mode
  help                       Description of the interactive help system
  revert                     Revert changes
  service                    Service Commands
  show                       Show running system information
  write                      Write running configuration to memory or terminal
      Related Commands
                     | no
                     Removes an existing WIPS policy |
For more information on WIPS Policy
            commands, see
WIPS Policy.
