channel-group
      interface-config-ge-instance
Assigns this Ethernet port to a channel group.
            Ethernet ports can be aggregated to form a channel group. They can be aggregated to form
            a minimum of one and maximum of two channel groups. A port can be a member of only one
            channel group at a time.
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
      Parameters
channel-group <1-4>
                     | <1-4> |
                     Specifies a
                        channel group number from 1 - 4. The number of channel groups supported
                        varies with the device type. For example:
                           - NX5500 – Supports three
                              channel groups
                           - NX75XX – Supports four
                              channel groups
                           - NX95XX – Supports two
                              channel groups
nx9500-6C8809(config-profile-testnx5500-if-ge1)#channel-group 1
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
 interface ge1
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
  channel-group 1
      Related Commands
                     | no |
                     Removes the channel group to which this port belongs |
