The smart-sensor feature uses an algorithm to auto-provision APs as sensors within a site. This algorithm is auto-triggered when the smart-sensor feature is enabled for the first time. However, re-calibration may be required in case of a change in the number of APs deployed or a change in the AP deployment pattern. In this case you will have to manually issue the 'trigger-smart-sensor' command to initiate Smart-sensor calibration.
Issue the 'trigger-smart-sensor' command through the controller (NX5500, NX7500, NX9500, NX9600 and VX9000) on the AP's RF Domain. Alternately, if the RF-Domain manager is an AP8533 or AP4xx, you can trigger Smart-sensor calibration locally on the RF-Domain manager.
Smart-sensor is supported only on the tri-radio AP8533 and AP4xx model APs.For information on enabling Smart-sensor, see smart-sensor.
trigger-smart-sensor on <RF-DOMAIN-NAME>
| trigger-smart-sensor | Manually triggers Smart-sensor calibration |
| on <RF-DOMAIN-NAME> | Triggers the calibration on a specified RF Domain.
nx9500-6C8809#trigger-smart-sensor ? on On RF-Domain <cr> nx9500-6C8809#
nx9500-6C8809#trigger-smart-sensor on smt-sensor
Alternately, if the RF-Domain manager is AP8533 or AP4xx, you can trigger Smart-sensor calibration locally on the RF-Domain manager.
ap8533-137E1D#trigger-smart-sensor
