no <PARAMETERS>
no <PARAMETERS>
                         no <PARAMETERS>  |
                         Removes this WLAN's settings or reverts them to default values, based on the parameters passed.  |
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
nx9500-6C8809(config-wlan-test)#no ? 802.11v Configure 802.11v parameters accounting Configure how accounting records are created for this wlan acl Actions taken based on ACL configuration [ packet drop being one of them] answer-broadcast-probes Do not Include this wlan when responding to probe requests that do not specify an SSID assoc-response Association response threshold association-list Configure the association list for the wlan authentication-type Reset the authentication to use on this wlan to default (none/Pre-shared keys) broadcast-dhcp Configure broadcast DHCP packet handling broadcast-ssid Do not advertise the SSID of the WLAN in beacons captive-portal-enforcement Configure how captive-portal is enforced on the wlan client-access Disallow client access on this wlan (no data operations) client-client-communication Disallow switching of frames from one wireless client to another on this wlan client-load-balancing Disable load-balancing of clients on this wlan controller-assisted-mobility Disable configure assisted mobility data-rates Reset data rate configuration to default description Reset the description of the wlan downstream-group-addressed-forwarding Disable downstream group addressed forwarding of packets dpi Deep-Packet-Inspection (Application Assurance) dynamic-vlan-assignment Dynamic VLAN assignment configuration eap-types Allow all EAP types on this wlan encryption-type Reset the encryption to use on this wlan to default (none) enforce-dhcp Drop packets from Wireless Clients with static IP address fast-bss-transition Disable support for 802.11r Fast BSS Transition http-analyze Enable HTTP URL analysis on the wlan ip Internet Protocol (IP) ipv6 Internet Protocol version 6 (IPv6) kerberos Configure kerberos authentication parameters mac-authentication Configure mac-authentication related parameters multi-band-operation Disable support for Agile Multiband nsight Nsight Server opendns OpenDNS related config for this wlan protected-mgmt-frames Disable support for Protected Management Frames (IEEE 802.11w) proxy-arp-mode Configure handling of ARP requests with proxy-arp is enabled proxy-nd-mode Configure handling of IPv6 ND requests with proxy-nd is enabled qos-map Disable the 802.11u QoS map element and frame radio-resource-measurement Disable support for 802.11k Radio Resource Measurement radius Configure RADIUS related parameters registration Dynamic registration of device (or) user relay-agent Configure dhcp relay agent info shutdown Enable the use of this wlan ssid Configure ssid t5-client-isolation Do not Isolate traffic among clients t5-security Configure encryption and authentication time-based-access Reset time-based-access parameters to default use Set setting to use vlan Map the default vlan (vlan-id 1) to the wlan vlan-pool-member Delete a mapped vlan from this wlan wep128 Reset WEP128 parameters wep64 Reset WEP64 parameters wing-extensions Disable support for WiNG-Specific extensions to 802.11 wireless-client Configure wireless-client specific parameters wpa-wpa2 Modify tkip-ccmp (wpa/wpa2) related parameters service Service to monitor to show no-service page to user nx9500-6C8809(config-wlan-test)#
The WLAN 'test' settings before execution of the no command:
nx9500-6C8809(config-wlan-test)#show context wlan test description TestWLAN ssid test bridging-mode local encryption-type tkip-ccmp authentication-type eap kerberos server timeout 12 kerberos server primary host 172.16.10.2 accounting syslog host 172.16.10.4 port 2 data-rates 2.4GHz gn wing-extensions wmm-load-information client-load-balancing probe-req-intvl 5ghz 5 client-load-balancing band-discovery-intvl 2 captive-portal-enforcement fall-back ip dhcp trust acl exceed-rate wireless-client-denied-traffic 20 disassociate enforce-dhcp broadcast-dhcp validate-offer http-analyze controller nx9500-6C8809(config-wlan-test)#
nx9500-6C8809(config-wlan-test)#no accounting syslog
         nx9500-6C8809(config-wlan-test)#no description
         nx9500-6C8809(config-wlan-test)#no authentication-type
         nx9500-6C8809(config-wlan-test)#no encryption-type
         nx9500-6C8809(config-wlan-test)#no enforce-dhcp
         nx9500-6C8809(config-wlan-test)#no kerberos server primary host
         nx9500-6C8809(config-wlan-test)#no kerberos server timeout
         nx9500-6C8809(config-wlan-test)#no data-rates 2.4GHz
         nx9500-6C8809(config-wlan-test)#no ip dhcp trust
         nx9500-6C8809(config-wlan-test)#no captive-portal-enforcement
         The WLAN 'test' settings after the execution of the no command:
nx9500-6C8809(config-wlan-test)#show context wlan test ssid test bridging-mode local encryption-type none authentication-type none wing-extensions wmm-load-information client-load-balancing probe-req-intvl 5ghz 5 client-load-balancing band-discovery-intvl 2 acl exceed-rate wireless-client-denied-traffic 20 disassociate broadcast-dhcp validate-offer http-analyze controller nx9500-6C8809(config-wlan-test)#
