crypto-cmp-policy
Creates a crypto Certificate Management Protocol (CMP) policy and enters
its configuration mode
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
crypto-cmp-policy <CRYPTO-CMP-POLICY-NAME>
Parameters
crypto-cmp-policy <CRYPTO-CMP-POLICY-NAME> |
Specify the crypto CMP policy name. If the policy does
not exist, it is created. |
nx9500-6C8809(config)#crypto-cmp-policy CMP
nx9500-6C8809(config-cmp-policy-CMP)#?
CMP Policy Mode commands:
ca-server CMP CA Server configuration commands
cert-key-size Set key size for certificate request
cert-renewal-timeout Trigger a cert renewal request on timeout
cross-cert-validate Validate cross-cert using factory-cert
no Negate a command or set its defaults
subjectAltName Configure subjectAltName value
trustpoint Trustpoint for CMP
use Set setting to use
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no |
Resets values or disables commands |
