option <OPTION-NAME> <0-250> [ascii|hexstring|ip]
| <OPTION-NAME> | Configures the option name |
| <0-250> | Configures the DHCP option code from 0 - 250 |
| ascii | Configures the DHCP option as an ASCII string |
| hexstring | Configures the DHCP option as a hexadecimal string |
| ip | Configures the DHCP option as an IP address |
Defines non-standard DHCP option codes (0-254)
An option name in ASCII format accepts a backslash (\) as an input, but is not displayed in the output. Use the show running-config command to view the output. Use a double backslash to represent a single backslash.nx9500-6C8809(config-dhcp-policy-test)#option option1 200 ascii
         nx9500-6C8809(config-dhcp-policy-test)#show context dhcp-server-policy test option option1 200 ascii nx9500-6C8809(config-dhcp-policy-test)#
| no (dhcpv4-server-policy-config) | Removes DHCP server options |
