interface-config-radio-instance
Enables Ekahau multicast packet forwarding. When enabled, Ekahau small, battery powered Wi-Fi tags are attached to tracked assets or assets carried by people. Ekahau processes locations, rules, messages, and environmental data and turns the information into locationing maps, alerts and reports.
ekahau [forward ip <IP> port <0-65535>|mac <MAC>]
| ekahau | Enables Ekahau multicast packet forwarding on this radio |
| forward ip <IP> port <0-65535> | Enables
                        multicast packet forwarding to the Ekahau engine
 TZSP is an encapsulation protocol, which is generally used to wrap 802.11 wireless packets.  |
| mac <MAC> | Configures the
                        multicast MAC address to forward the Ekahau multicast packets
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#ekahau forward ip 172.16.10.1 port 3 nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 description "Primary radio to use" channel 1 data-rates b-only beacon period 50 beacon dtim-period bss 1 5 beacon dtim-period bss 2 2 beacon dtim-period bss 3 5 beacon dtim-period bss 4 5 beacon dtim-period bss 5 5 beacon dtim-period bss 6 5 beacon dtim-period bss 7 5 ................................................. beacon dtim-period bss 16 5 antenna-gain 12.0 aggregation ampdu tx-only aeroscout forward ekahau forward ip 172.16.10.1 port 3 antenna-mode 2x2 --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
| no (radio-interface-config-command) | Uses default Ekahau multicast MAC address |
