use
         bridge
Associates a captive-portal, access control list (IPv4, IPv6, or MAC), and/or a URL filter with this bridge VLAN
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
         use [application-policy|captive-portal|ip-access-list|ipv6-access-list|mac-access-list|url-filter]
         use application-policy <APP-POLICY-NAME>
         use captive-portal <CAPTIVE-PORTAL-NAME>
         use [ip-access-list|ipv6-access-list|mac-access-list] tunnel out <IP/ipv6/MAC-ACCESS-LIST-NAME>
         use url-filter <URL-FILTER-NAME>
      Parameters
                     | use
                        application-policy <APP-POLICY-NAME> |
                     Enforces
                        application detection on this VLAN bridge
                           - <APP-POLICY-NAME> –
                              Specify the application policy name (should be existing and
                              configured).
                           - For
                              more information on application definitions and
                              application policy, see application and application-policy.
                     | use
                        captive-portal |
                     Applies an
                        existing captive portal configuration to restrict access to the bridge VLAN
                           configuration A captive
                           portal is an access policy for providing temporary and restrictive access
                           using a standard Web browser. Captive portals provide authenticated
                           access by capturing and re-directing a wireless user's Web browser
                           session to a captive portal login page where the user must enter valid
                           credentials to access to the network. Once logged into the captive
                           portal, additional terms and agreement, welcome, fail, and no-service
                           pages provide the administrator with a number of options on captive
                           portal screen flow and user appearance.
                           - <CAPTIVE-PORTAL-NAME> – Specify the captive portal name.
use [ip-access-list|ipv6-access-list|mac-access-list] tunnel out <IP/IPv6/MAC-ACCESS-LIST-NAME>
                     | use |
                     Sets this VLAN
                        bridge policy to use an IPv4/IPv6 access list or a MAC access list |
                     | ip-access-list |
                     Associates a
                        pre-configured IPv4 access list with this VLAN-bridge interface |
                     | ipv6-access-list |
                     Associates a
                        pre-configured IPv6 access list with this VLAN-bridge interface |
                     | mac-access-list |
                     Associates a
                        pre-configured MAC access list with this VLAN- bridge interface |
                     | tunnel out
                        <IP/IPv6/MAC-ACCESS-LIST-NAME> |
                     The following
                        keywords are common to the ‘IPv4/IPv6 access list‘ and ‘MAC access list‘
                           parameters:
                           - tunnel – Applies IPv4/IPv6
                              access list or MAC access list to all packets going into the tunnel
                                 - out – Applies
                                    IPv4/IPv6 access list or MAC access list to all outgoing
                                       packets
                                       - <IP/IPv6/MAC-ACCESS-LIST-NAME> – Specify the
                                          IP/IPv6 access list or MAC access list name.
                     | use
                        url-filter |
                     Sets this VLAN
                        bridge to use a URL filter |
                     | <URL-FILTER-NAME> |
                     Specify the URL
                        filter name. It should be existing and configured. This option enforces URL filtering on the VLAN
                           bridge.
nx9500-6C8809(config-profile-default-rfs4000-bridge-vlan-1)#use mac-access-list tunnel out PERMIT-ARP-AND-IPv4
nx9500-6C8809(config-profile-default-rfs4000-bridge-vlan-1)#show context
 bridge vlan 1
  ip igmp snooping
  ip igmp snooping querier
      Related Commands
                     | no |
                     Disables or
                        reverts VLAN Ethernet bridge settings |
