process-cpu
Configures the EX3500‘s CPU (processor) utilization rising (upper) and falling (lower) threshold
values. Once configured, the system sends a notification when the CPU utilization exceeds the
specified rising limit or falls below the specified falling limit.By customizing an EX3500‘s memory and CPU utilization‘s upper and lower thresholds, you
can avoid over utilization of the EX3500's processor capacity when
sharing network resources with an NX series service platform or a WiNG VM.
- Service Platforms — NX 95XX, NX 96XX, NX 7510
Syntax
process-cpu [falling-threshold|rising-threshold] <1-100>
Parameters
| process-cpu |
Configures the EX3500‘s CPU utilization rising and
falling threshold values. The system generates a notification when either of these
limits is exceeded. |
| falling-threshold <1-100> |
Configures the falling threshold for the EX3500‘s CPU
utilization
- <1-100> – Specify the
falling threshold as a percentage from 1 - 100. The default is 70%.
| rising-threshold <1-100> |
Configures the rising threshold for the EX3500‘s CPU
utilization
rising threshold as a percentage from 1 - 100. The default is 90%.
nx9500-6C8809(config-ex3500-management-policy-test)#process-cpu falling-threshold 60
nx9500-6C8809(config-ex3500-management-policy-test)#process-cpu rising-threshold 80
nx9500-6C8809(config-ex3500-management-policy-test)#show context
ex3500-management-policy test
http secure-server
enable password level 3 7 12345678901020304050607080929291
snmp-server notify-filter 1 remote 127.0.0.1
memory falling-threshold 50
memory rising-threshold 95
