Removes the client identity associated with the client identity group
no [client-identity|load]
no client-identity <CLIENT-IDENTITY-NAME> precedence <1-10000>
no load default-fingerprints
                         no client-identity <CLIENT-IDENTITY-NAME> precedence <1-10000>  |
                         Disassociates a specified client identity from this client identity group
 The client identity rule is applied based on its precedence value. Lower the value, higher is the precedence. Therefore, a client identity with precedence 5 gets precedence over a client identity having precedence 20.  |
| no load default-fingerprints | Disables automatic loading of built-in, system-provided client identity fingerprints |
nx9500-6C8809((config-client-identity-group-test)#show context client-identity-group test client-identity test precedence 1 <exsw5>(config-client-identity-group-test)#
nx9500-6C8809((config-client-identity-group-test)#no client-identity test
