Removes a deny, permit, or disable rule
no [deny|disable|permit]
no [deny|permit] [<NETWORK-SERVICE-ALIAS-NAME>|icmp|ip|proto|tcp|udp] <RULE-PARAMETERS>
no disable [deny|permit] [<NETWORK-SERVICE-ALIAS-NAME>|icmp|ip|proto|tcp|udp] <RULE-PARAMETERS>
no [deny|permit] <NETWORK-SERVICE-ALIAS-NAME>icmp|ip|proto|tcp|udp] <RULE-PARAMETERS>
                         no [deny|permit]  |
                         Removes a deny or permit rule from the selected IP access list  |
                         <NETWORK-SERVICE-ALIAS-NAME>  |
                         Removes a deny or permit rule applicable to the specified network-service alias
                         icmp  |
                         Removes a deny or permit rule applicable to ICMP packets only  |
                         ip  |
                         Removes a deny or permit rule applicable to IP packets only  |
                         proto  |
                         Removes a deny or permit rule applicable to protocols (other than IP, ICMP, TCP, and UDP)  |
                         [tcp|udp]  |
                         Removes a deny or permit rule applicable to TCP/UDP packets  |
                         <RULE-PARAMETERS>  |
                         Enter the exact parameters used when configuring the rule.  |
                         rule-precedence <1-5000> rule-description <LINE>  |
                         Specify the precedence assigned to this deny/permit rule.
 Note: The system removes the rule from the selected ACL.  |
                         no disabled [deny|permit]  |
                         Removes a disabled deny or permit rule from the selected IP access list  |
                         Removes a disabled deny or permit rule applicable to the specified network-service alias
                         icmp  |
                         Removes a disabled deny or permit rule applicable to ICMP packets only  |
                         ip  |
                         Removes a disabled deny or permit rule applicable to IP packets only  |
                         proto  |
                         Removes a disabled deny or permit rule applicable to protocols (other than IP, ICMP, TCP, and UDP)  |
                         [tcp|udp]  |
                         Removes a disabled deny or permit rule applicable to TCP/UDP packets  |
                         <RULE-PARAMETERS>  |
                         Specify the precedence assigned to this disabled deny/permit rule.
 Note: The system removes the disabled rule from the selected ACL.  |
Provide the rule-precedence value when using the no command.
The following example shows the ACL ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-ip-acl-test)#show context ip access-list test deny proto vrrp any any log rule-precedence 600 deny proto ospf any any log rule-precedence 650 nx9500-6C8809(config-ip-acl-test)#
nx9500-6C8809(config-ip-acl-test)#no deny proto vrrp any any rule-precedence 600
         nx9500-6C8809(config-ip-acl-test)#no deny proto ospf any any rule-precedence 650
         The following example shows the ACL ‘test‘ settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-ip-acl-test)#show context ip access-list test nx9500-6C8809(config-ip-acl-test)#
